Check Speaker has nothing to do with High Def or HDMI
One or more leads of one of your speakers is not connected properly. Check the manual
Look closely at the rear connector panel of the receiver and look for pieces of stray strand wire that may be touching the speaker A binding post and the receiver chassis. If you are not using strand wire connection to the binding post then check whatever connector type you are using such as banana plug or spade plug for breakage or corrosion, the same goes for the speaker cable itself which isn't always so easy to detect. A few broken strands can cause a problem.
If it is clean, turn off the receiver and disconnect the speaker cable. Check the binding post for tightness; if you can wiggle it then it is broken and needs to be replaced.
SOURCE: no sound
Check the settings on the receiver. You may need to switch the dvd from analog to digital or hdmi.
SOURCE: can't get audio from HD TV to run through Yamaha receiver speaker
be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
SOURCE: Yamaha Receiver sound cuts out with Dolby Digital.
Your problem is related to HDMI technology not the Receiver. HDMI in it's current version 1.3b has worked out 90% of the current problems being reported by HDMI users. it's a problem with HDCP digital copyright protection and the recording industry not wanting us "consumers" to duplicate or record their DVD's. Your receiver and every other receiver with version 1.1,-1.2, & 1.2a just don't cooperate with BluRay and even HD Cable or HD Sat receivers. If you just purchased this receiver recently, return it and get an 09' model or equivalent with 1.3a or 1.3b HDMI technology. If this unit is "un-returnable" then, what needs to happen is you need to run component video and digital audio to the receiver OR Run your HDMI directly to your TV and run a Digital Coaxial to your DVD audio input on the receiver. Depending on how many sources you are running to the TV via HDMI will be limited to the TV's capability (how many HDMI inputs)
Now, if your TV is 50" or smaller, the difference between running HDMI and Component is unmeasurable to the human eye. So, if you have to run component, don't sweat it! just use good cable, ie. Monster, Phoenix, Translucent etc. I do theese installs every day, and I still prefer Component or DVI if available over HDMI. They just haven't proved the reliability to me yet and we're three years in! Hope this helps
SOURCE: Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
This solution helps! I got this unit from a friend and there was no sound from the left channel, and after playing with the input knob, there was sound.
I sprayed alot of electronic cleaner and it worked like magic.
the unit is now in full working mode.
