Question about Kodak Esp 3250 Allinone Multifunction ( C InkJet Printer
Error code 3508 after installing a new cartridge
Anonymous
    Sergeant:
  • 220 Answers
As Kodak suggests in these cases - upgrade the firmware for your printer.
  1. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
If the error continues, try to contact Kodak
Posted on Oct 03, 2011
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: after replacing the color cartridge,
You have a bad cartridge. They have chips in them. Return it.
Posted on Jul 31, 2011
Reset code for toshiba photocopier machine model 3508 error code c447
08-2002 set to "0"
If problem persist, u need to check fuser unit especially themistor
I have installed a new ink cartridge and it keeps telling me to install new cartridge erroe code 3508
when you installed the new one the others may need changed due to being very low.
1helpful
Help me please, i have new HP j3508, but when i install new cartridge into my HP 3508, the message on the screen says :"Cartridge Error" cartridge on right is not intended for this printer... help me
You need to remove the cartridges, see to it that the colored cartridge are olaced in its right location the same as with the black cartridge to avoid an error.
I have red light the second (toner) and the last lamp (exlamation). The first one i don't care, it was red since i charged it, but since the exclamation is red doesn't do anything and the green...
The toner cartridge is not installed, or the printer detects a toner cartridge error. The error is caused by a defective cartridge, an unsupported cartridge an invalid refill, or a cartridge meant to be used in another geographic region.
If the toner cartridge is not installed, install it. If the toner cartridge is installed, remove it and install a new toner cartridge.
For Cartridge errors, Press and release the right button twice briefly to display secondary error codes.
For further assistance, please contact Lexmark Technical Support.
1helpful
I have a Kodak ESP 3250. I always print Black Only, but after a few months I get a 3508 error code telling me to replace my color cartridge. I cannot use the printer, period!!! Since I only print...
If this printer is like some of the HP printers I have serviced in the past, many printers like this use a tiny bit of color as a "primer" to make the black "blacker" and to prevent bleeding in systems where the color is dye and the black is pigment.
A number of printers may allow a "use black only" in the driver settings, but many other printers will simply refuse to print if the color runs out, even if you are printing black and white.
The short answer is, chances are, you need to replace the color cartridge.
11helpful
E 5 error code
this is what your error means
E5-5
= The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly.
are you using brand new supported ink cartridges?
are they in the right way?
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
3helpful
2answers
Error code U140 check ink because I used a non-OEM cartidge
You need to buy the ink with the new chip installed, or buy a resetter. The only way to print now is with a new cartridge either Canon, or with a new chip.
1helpful
Black ink is faded
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Kodak Esp 3250 Allinone  Multifunction (  C InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
