Hi Linda Bailey,
If it keeps washing it could be that it is unable to progress to the Drain or Spin cycle. The likely culprit could be the Drain Pump Filter. To clean the Drain pump filter:
1) Plug the appliance out.
2) Open the small compartment below the door (Either Right or left hand corner) You will see a small pipe and a circular lid with a handle.
3) Drain the water by using the small pipe (Get a bowl for the water!), take of the cap of the hose or use the tap on the pipe on some models.
4) Once all the water is drained, open up the cap (Again.. Keep the bowl close by for spillage) by turning it anti-clockwise. Once off, clean the filter which is found on the cap.
5) stick your fingers into the now open compartment, be sure to clean out any obstructions, and feel if the impeller inside can turn freely.
THATS it! Now re-insert the cap, and close the pipe if open. Plug your machine in and viola!
It should solve your problem.
If not, let me know.
Kind Regards
JEDEMEYER1
