SOURCE: Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
SOURCE: dell dimension 4700 blinking yellow light
You clearly have an SMPS(power supply issue). Not 3 days ago I worked on my dad's PC that had the same problem. I found that the board had some leaky caps, and the circuit board inside it partially burnt. I could get it working by replacing the caps, but dont know how long it will last(I'll be getting a new PC soon anyway). Its advicable you replace the power supply. Should cost you around 30-50$ at MOST!
SOURCE: when I turn on my computer my monitor turns on briefly only
Sounds like a graphics card problem. Have it checked and replaced if necessary
