Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it. If you're out of warranty, there are third party place that replace them such ascamera lens repairs. If you want to do it yourself, there are also free camera repair guidewebsites that show you how to replace the lens, the replacement part is usually available on ebay.
Well Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... You can follow the below link to know more -
