Have a 2001 v star 1100 was riding down the road and died found it blew a 30 amp fuse replaced it then blew again even with the key off it still blows the fuse
Jeff, Make sure battery is good and charged,check all fuses, I believe there will be a 30 amp that could be blown, other then that remove battery connections and clean, check ground connection to frame/engine also, quite common for bikes to have dirty or loose connection and loose all power.
Check the attached links forums,instruction and guides, last link is a good trouble shooting link.Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://www.starbikeforums.com/forums/49-v-star/9371-good-battery-no-power-1100-v-star.html
under your seat there is a bunch of wires 3 of the yellow i think wires goes to a pigtail thats the wiring harness for your stator and rectifier i had 03 1100 spirit shadow and 1 day i was riding and it jus quit on me i finally got it home broke it down n noticed the fuse kept popping every time i changed it then i found the melted pigtail looking for a short so i cut pigtail out straight wired each wire an never had a problem since.
sounds like a problem i had with my v star if u can charge it and it starts and runs for a bit then dies again check the rectifier which charges the bike
Well it's temping to put in biggfer fuses as the problem gets worse but the size of the fuses are to keep you from burning things up so you've from your probem with a 30 amp smoke test. The raditor fan wire is melted somewhere in the wire harnes to the wire for the trck lock or even key on circirts. the likly place to look is inside the stering collum. It takes the skills of removing the steering whel and the lcok plate and even then thats does'nt have to be where the problem is. You need to look under the dash after you remove the covers and use you nose to smeel for the burnt wiring and open up any thing the smells like it's been hot and anything the appers melted together. once a harness is found melted you need to seragete all the wires in the loom but don't cut the wires justy seaparte them. once you think you've got then all pulled apart so no bear wires touch each other or any meal parts put in the correct size fuses and see if you can connect the battery with out a spark. if you can you may then start checking to see what works and what does'nt.. This all sounds like too much work or too hard to do then you'll need to pay someone theat knows alot about car wiring problems to do it for you. I'll been doing this kind of work for the last 20 years and a'm alawys finding new things that are fried and burnt up. We all charge by the hour to do this work so the most experieced mechanic that works on cars like yours will probly find and fix the problem the fastest. therefore they may charge more per hour but their likly to get it right quicker and it'll stay fixed after they fix it.. This is the most likly kind of work to go sour after it's fixed cause they might miss a circuit that you use and they did'nt try. and as soon as it burns again it's back to the drawing board and if big fuses are use the fire can take the whole car.
Many cars have the cooling fan on a thermostat or time delay, to allow it to run for a short period of time after the engine turns off, to cool the engine off. You may have just never noticed it before. So I wouldn't worry about that. Your real problem is the blowing fuses, apparently you have a short somewhere in your wiring. Putting in bigger and bigger fuses is a great way to set fire to your wiring harness. It's possible that the wire is pinched or chafed somewhere, and perhaps when you hit a bump just right, it touches and shorts. You may have to take this to the Chevy dealer or a GOOD independent shop to have them chase it down. Unless someone out there knows exactly what this is, it could be a tough one to find.
Use a +12 volt trouble light and turn key on, start at fuse and shake wires while following wires. Sougs like a intermittent short. Check GRN at ket also.
that fuse feeds power to fuel pump relay circuit that feeds pump could be defective pump,or damaged circuit wires that shorts out! and not a good idea to put higher fuse in circuit could cause more damage to circuit! but i know when your stuck, u do what it takes,so inspect circuit related to fuse,
