SOURCE: transferring photos from hitachi hdc-1061e
Sorry, I haven't been able to find any software, but you can try the
following workaround:
1. Plug in the camera to the PC and ensure it is detected by the PC.
2. Right click START button and select Explore.
3. From the left panel, scroll to the drive corresponding to your camera. (It
will usually be located after the last DVD/CD ROM
Drive letter.
4. Click on that drive to expand the folders in the right pane.
5. Search for the relevant pictures from a folder within that drive.
6. Copy the required pics (Press CTRL and click on pics in case you want to
select more than one pic.
7. Once you copied all the needed pics, select a folder on your computer (or
create a new one) and paste the pics into this folder.
8. You're done :)
Hope that helps! Should you have any further questions, please feel free to
post them here.
P.S. - If you find that the solution/answer I provided led you
to, or resulted in a fix, please close the ticket with a FixYa! rating.
I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: I lost my digital camera Hitachi HDC-1097E USB
Kindly go to the below, you can actually get what you are looking for here;
http://www.amazon.co.uk/hitachi-digital-camera-Electronics-Photo/s?ie=UTF8&rh=n%3A560798%2Ck%3Ahitachi%20digital%20camera&page=1
Copy it and paste it on your web browser to see all the products and accessories amazon can offer concerning Hitachi camera. Thanks
SOURCE: Lost my camera manual. How do I format the sdhc
Go into the menu and find "format"...follow the on-screen instructions.
SOURCE: i dropped my hitachi HDC
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside.Alsoit can be due to failure of the drive motor in the zoom and auto focus sections. It will require good tools and experience to remove and check the conttrol panel and the servo drives. If not you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
