Question about Nor-Lake Walk In Cooler 6ft x 8ft Norlake Indoor No Refrigeration
P1 error code - Nor-Lake Walk In Cooler 6ft x 8ft Norlake Indoor No Refrigeration
Posted by Barbie on
Leo Ponder
    President:
  • 3,773 Answers
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Oct 04, 2011
Blue star Visi cooler subzero error code p1
Amazon.com: Questions And Answers: WHAT DOES THE P1 error code mean??
www.amazon.com/.../ref=ask_dp_dpmw_al_hza?asin...
Amazon.com, Inc.Oct 19, 2014 - Hi David, According to the manual: "P1- Unit is defrosting-- Allow the unit time to automatically defrost. The error will clear after the unit self ...
Jul 26, 2015 | Dehumidifiers
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
I have a polar wind portable air conditioner/dehumidifier/fan with swing louvers model # MPN4-12CRN1-BH8 I cannot get the protection code P1 to go away do you have any suggestions? When I first plug it in...
Check the back of the manual that came with it. I find two things for a P1 Error.
Midea AC "R" Series Error Display = P1
Error Code Definition = Over voltage or too under voltage protection
On a portable unit
P1 or H8 - Water reservoir is full.
Oct 22, 2017 | Heating & Cooling
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
Hobart am-15 ml-130038 displaying p1 error
I replaced the probe temp according to error code P1 but the display still shows error P1. Is there any suggestion for further troubleshooting?
Nov 08, 2011 | Hobart 29 in. AM15-1 Free-Standing...
Why get a P1 error code on my Rheem tankless RTG-64xp?
1) I cannot find Rheem error code P1
http://www.palomatankless.com/owners/homeowner+trouble.lasso
http://www.palomastore.com/paloma_error_codes.html
2) BOSCH does not show P1 either:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
3) Best I could find is that folks with P1 error code report tankless fires for short period, and then turns off.
This implies air, fuel or vent problem, and can be internal, external or combination.
4) P1 appears frequently on control board descriptors, which might imply the error is control board malfunction.
5) Call Rheem 1-800-432-8373, and then add a comment to this thread and let folks know what you discover.
6) I will also call Rheem when time permits, and post what I discover.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Rheem Water Heaters
Polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Jul 24, 2009 | Kenmore 54501 Dehumidifier
P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Sep 13, 2008 | Danby DDR2506 Dehumidifier
Refrigerators Logo
2,224 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
