Oh? Did this just happen?
Or are you installing this motherboard for the first time?
Will help to know, because you may not have the necessary needed, power cables plugged in,
OR;
One or more of them may be loose.
I also see that English is not your native language. I apologize that English is all I know, in advance. If you see something printed here you do not fully understand, post back in a Comment.
We will work it out.
Gigabyte GA-8I945GZME-RH,
(GA-8, capital I, 945GZME-RH, not GA-81945GZME-RH ),
http://www.geeks.com/details.asp?InvtId=GA-8I945GZME-RH-BOGigabyte Support > GA-8I945GVME-RH motherboard > Main Support page,
http://ee.gigabyte.com/products/page/mb/ga-8i945gzme-rh/download/See where it states -
Advantages/ Overview/ Specification/ Downloads/ News/ Awards?
Look at the black bold subheading under it - Download type: and under it - Drivers - in the box.
Click on the blue arrow to the right of the box.
In the drop down list click on - Manual
In the list go to the second file down.
English - 1003 - 5.4Mb - 10/07/2006
Left-click on the blue -> FTP
This is a PDF file. After you click on FTP, it may take up to 30 seconds before the first page comes up.
Power cables to motherboard;
1) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain242) 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4Notice how both power cable connectors have a LOCK on the side?
Look at the photo in the middle for both power cable links, above.
The connector on the motherboard has a TAB, that the Lock goes over.
Hooked end of Lock, goes over Tab on female motherboard connector.
When the hooked end of the Lock is over the Tab, on the motherboard connector, you KNOW the power cable is plugged in tightly.
If not, there is your problem.
Do you have the SATA power cable plugged into the Harddrive, tightly?
SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sataDo you have the SATA data cable plugged in tightly to the motherboard, AND to the Harddrive?
http://en.wikipedia.org/wiki/File:SATA_ports.jpgCPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
Does NOT mean personal computer.
CPU is on? You mean the Power Supply's fan is running, and computer case fans, and Processor fan.
Does not mean the Processor is on.
Why?
Primer:
You press the Power On button. This plastic assembly pushes against a Power On switch,
http://www.axiontech.com/prdt.php?item=78201The Power On switch is a Momentary Contact Switch.
It closes very briefly, which in turn briefly completes a circuit.
The Soft Power On circuit.
The Power Supply always has a constant 5 Volts present, when it is plugged into power. A 5 Volt reserve power, called the 5 Volt Standby power.
Closing the Power On switch briefly provides a Ground, and completes the Soft Power On circuit.
The Soft Power On circuit excites the Power Supply, and turns it on.
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program, on the BIOS chipset, is initialized. (BIOS program)
BIOS looks to see what devices are connected, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(Windows XP, and Windows 7, are two examples of an O/S)
You are getting a 'Cable not connected' error message, which means BIOS hasn't turned the Processor on.
Is the 4-pin ATX +12 Volt power cable plugged in, and tightly? It's power for the Processor.
Post back in a Comment.
Regards,
joecoolvette
