Question about Microsoft Windows Media Player
How do I delete a playlist from windows media player
Posted by ginger_w on
virtual_a
  • 531 Answers
Hi ginger w
DELETING PLAYLIST FROM WINDOWS MEDIA PLAYER
You don't say which version of Windows Media Player you have or which Windows Operating System you are using.
However, generally, to delete a playlist:
Single left click to highlight the playlist to be deleted > single right click on highlighted playlist > single left click on 'Delete' > Are you sure? (single left click to select either Delete from library only or Delete from library and computer) > single left click OK.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Posted on Oct 02, 2011
How do I delete a playlist from windows mefdia player
Hi ginger w
DELETINGPLAYLIST FROM WINDOWS MEDIA PLAYER
I hope this helps.
Oct 02, 2011 | Microsoft Windows Media Player
I have a Sansa Clip 4GB MP3 Player and I have loaded several playlists onto it. When I try to play one of the playlists it will shift to a different playlist and start playing that. I cannot access my...
Save what you want and Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Deleteing Playlist: Open my computer double click my music Here you should find the folder my play list double click and delete file .wpl or .m3u these are the playlists....You can also go to search type .wpl enter when located delete remember where file was located...Windows Media Player will find them also and you can delete from there.. (Library)
Apr 08, 2010 | SanDisk Sansa Clip MP3 Player
Wen i delete music from the library in windows media player it also deletes it from my philips gogear mix how do i stop this
Playlists to sync on the player can be set in Windows Media Player.
When selecting the Library or Sync tab in WMP full view, the GoGear is visible on the left side in the list.
The player can be either connected seeing the player's icon or not connected seeing the player's map name.
Right click the GoGear Mix and select Setup Sync...
The box, Sync this device automatically probably is selected.
Prevent the player from unattended synchronizing by unchecking this box: Especially when you're removing lists on the computer frequently.
Setup the the playlists to sync first and synchronize manually after that.
Temporary "Sync this device automatically'' must be selected, to be able to edit the playlists to synchronize.
On the right half of the Device Setup screen there''s the "Playlists to sync''.
Under playlists to synchronize, first remove all playlists or those you are going to delete in the library, before synchronizing.
When needing more information, just post a comment.
Jan 06, 2010 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
·         Open up Windows Media Player(WMP) on your computer. To add a track to a playlist on your computer using WMP, click to highlight an item.
·         Right-click on the item that you want to add, then select Add to Playlist. A pop-up window will appear. Select an existing playlist or add a new one. Your selection is now added to your playlist.
·         Delete a track. When you do not want a track on your playlists anymore, you are able to delete it. To delete tracks and playlists, click to highlight an item. Right-click the item and select Delete from Library to delete it.
·         To Edit track information, click on a track. Right-click and select Edit. Click on the text boxes to edit relevant information.
·         Once all changes have been made, connect your GoGear to your computer with your USB cable and download the new playlists.
Sep 24, 2008 | Philips Audio Players & Recorders
Cannot load playlists
Try sync your player with winamp. It synced the whole winamp media library (including playlists). Hope this can help.
Jun 10, 2008 | Samsung YP-K3 MP3 Player
How to delete to go playlist
Open the 'Playlist on the go' and scroll to the last in the songs list. There u will find an option 'Clear Playlist....
From there you can delete the Songs from Go Playlist
Apr 13, 2008 | Audio Players & Recorders
Iriver Troubles
Delete the playlist and try to re-add using windows Media Player - make sure EVERY song in the playlist is in the right format
Mar 31, 2008 | iRiver H10 MP3 Player
Im trying to change the playlist of my Philips Go Gear 4gb
You will have to delete the playlist, change the items you want to change in Windows Media Player, and then re-load the playlist onto the GoGear.
Mar 14, 2008 | Philips GOGEAR SA6045 MP3 Player
No playlist found
One of the pesky features of windows Media Player is that if you delete the song/playlist from the computer's harddrive, and then resync your device to that same computer, then oftentimes the song/playlist disappears. Reacquire the song/playlist, and then try resyncing to the goGear again.
-Tha Mp3 Doctor
Dec 06, 2007 | Philips GoGear HDD1830 MP3 Player
Playlist
Were you using Windows Media Player to make the playlists? Firmware upgrade resolves playlist issue
Nov 14, 2007 | RCA OPAL M4001 MP3 Player
Microsoft Windows Media Player Logo
96 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
