SOURCE: Need the keyboard component for a new MSI A6200
You can search a replacement item from Ebay, online auction, AMAZON or the MSI website itself.
Type the keywords on Google search bar
Thanks. Cheers
SOURCE: Hi I have a MSI
Hi nick dunnmai,
Here are the things that you can try to diagnose the issue.
- Boot to "Safe Mode with Command Prompt" by pressing F8 (or F10..depending on the brand of the unit), if you can type from there, you are 100% sure that you're having software issue. In this case, you can perform virus scan, registry fix or reinstall the whole operating system.
- Replace the keyboard if it is not working in "Safe Mode". You can purchase a keyboard replacement or send back the unit to MSI repair center if still under warranty.
Hope this helps. Any comment is highly appreciated.
SOURCE: The two Shift Keys don't work on my MSI A6200
Try this link:
http://www.ebay.com/sch/i.html?_nkw=MSI+A6200+keyboard&_sacat=0&_odkw=MS-1681+keyboard&_osacat=0&_trksid=p3286.c0.m270.l1313
Let me know if this answers your question and good luck..
SOURCE: my msi cr640 keyboard is not working...please help!!!!!
Has there been any damage? Drop? Jarred? Possible loose connection? I'm sure you have unplugged, removed battery, plug in, rebooted? Are ALL you Windows and MSI updates current? You may have to open the laptop and verify the connection and repair/replace the keyboard. Take a look a MSI Support for a Manual and drivers: http://www.msi.com/product/nb/CR640.html#/?div=Overview
Physically look in the radiator under the cap(if one exsist's) when cool, for coolant level, and check the valve in the cap for sticking. If air is present in the radiator it can't get out, and more coolant can't get in,(from the overflow). Either clean the cap or replace it and check that it is the CORRECT cap.
If radiator is low on coolant fill it to overflowing, replace cap, and check that coolant overflow is filled to the COLD line or mark. The overflow is normally where you would add coolant. (never overfill the overflow)After refilling as outlined above, check the level every morning for 2 or 3 days until coolant level stops dropping below the cold mark and add coolant to the overflow ONLY. Do not open the radiator cap. Also, if you have even a tiny coolant leak anywhere in the system, air will get drawn in, instead of coolant from the overflow.
For more OVERHEATING PROBLEMS try these...
Radiator fins dirty, clean with a strong stream of water, not high pressure water.
Radiator clogged, try backflushing it, or replace.
Thermostat stuck open or shut, replace it. Or installed BACKWARDS.
Water pump worn out, can no longer move enough coolant, replace it.
Fan shroud broken or missing....
Electric Fan(s) not working, Check the fan, relay, fuse and engine temperature sensor's.
Belt driven fan, belt slipping, fan clutch is bad, fan blades have flattened out.
Air dam under front bumper is gone, loose, or broken. It actually has a purpose other than scraping on the driveway or curbs. It forces air up into and thru the condenser and radiator. If it's loose, airflow can actually push it out of place making it useless or blocking the airflow. Along with that, there may also be a plastic piece attached to the bottom of, and wraps up behind the bumper. If it's loose, airflow can actually push it out of place blocking the airflow. Simply reattach it with 4 or 5 screws.
Also, if the vehicle has A/C and electric fans, one fan is dedicated to the A/C and should come on almost the instant the A/C is turned on. The engine fan will run even with the key off, that is normal. The system is trying to cool itself. Hope this helps.
Normally, you shouldn't have to bleed the cooling system but, there are two bleed valves. (these are the most logical locations)One is just above the water pump, and the other is on the thermostat housing. They are really small, and due to the age of your car, they will be brittle and almost impossible to open without breaking them.
You don't want to break them. If you are hearing air circulating thru the cooling system, try this and let me know how you make out.....
Physically look in the radiator under the cap when cool, for coolant level, and check the valve in the cap for sticking. If air is present in the radiator it can't get out, and more coolant can't get in,(from the overflow). Either clean the cap or replace it and check that it is the CORRECT cap.
If radiator is low on coolant fill it to overflowing, replace cap, and check that coolant overflow is filled to the COLD line or mark. The overflow is normally where you would add coolant. After refilling as outlined above, check the level every morning for 2 or 3 days until coolant level stops dropping below the cold mark and add coolant to the overflow ONLY. Do not open the radiator cap.
