Hello, Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Can't help ya, as mine is doing the same thing. Not so much none of it, but there is always some left over in the f.s. compartment. I have tried adding water, but there is still some left over. It dries, and gets gummy. Every so often, I remove the drawer and clean it off.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
hi there are you using concentrated softner if so water is down as some softners are to thick to go through the dispenser also give the whole drawer a soak in hot soapy water incase there are any blockages.
