Question about Mitsubishi VS-50501 50" Rear Projection Television
SOURCE: Mitsubishi VS-50501 TV turns off by itself
i have the same problem repair man has had it for 6 weeks did you solve the problem yet i need help
Posted on Oct 31, 2007
SOURCE: mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Posted on Apr 09, 2008
SOURCE: Mitsubishi VS-45603
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
Posted on Sep 18, 2008
SOURCE: vs-50501 50inch projection with no picture only sound!
Are there any other symptoms like blinking lights on the front or just no picture? This could be as simple as a few capacitors being bad or something more severe. Can you solder? Do you feel comfortable working inside the set where there are potentially dangerous high voltages present even with the set unplugged? Let me know and we'll work through the diagnostic process and hopfully resolve this.
Thanks,
Dan
Posted on Dec 31, 2008
SOURCE: manual for mitsubishi vs 5043 cannot program for
If you go into the main menue with the Mitsubishi remote, there should be a set up icon for programing stations. It should give you a selection for cable and or standard tuning. Select cable then press auto program.
Hope this got it done,
Skyassoc
Posted on Jun 19, 2009
