Casio Cassiopeia E-100 Pocket PC Logo
Question about Casio Cassiopeia E-100 Pocket PC
Casio e100 charges, but doesn't power on.
I recently aquired a casio e100 on ebay. It is in phenomenal condition, but it doesn't power on. When I plug it in, the light is green (so its charging) but when i try powering it on it doesn't turn on. I tried taking it apart and cleaning off the rom, and it still doesnt work. Any advice?
Posted by weatherman92 on
  • Larry Ng
    Larry Ng Jun 15, 2022
    the battery is no good at all. 23 years old it is, and no battery ever lasted 2 decades
    and in fact fail faster parked unused, allowing the lithium batter to go why to low makes it DIE FAST
    made 1999, use it for a paper weight. or coffee table piece, say it is real STAR Trek communicator from KIRK your own buddy. Even call him for batteries, imported from Pluto. (my home planet )
ray gallant
    Top Expert:
  • Casio Master
  • 74,163 Answers
Buying JUNK from EBAY is not fixable
Posted on Nov 29, 2021
5 Related Answers
Misty Hoffman
  • 374 Answers
SOURCE: Charging/power problems on EX-Z55
The problem might be your charger. I would call repairs and tell them you have a defective charger and they can check it for you. You can reach them at 800-706-2534 and then keep choosing option 1 and that will take you into Casio's repair department.
Posted on Jul 17, 2007
Anonymous
SOURCE: not turning on.
I have the same problem, I rang Casio and they are sending me a replacement battery. Apparently they have had problems with the NP 20 battery and have assured me that the lifespan of a battery should be more than a year and that the new one should be fine.
Posted on Apr 07, 2008
Anonymous
SOURCE: Casio Exilim EXZ75 battery not charging
I had the same problem before and you have to call the company's Technology Support phone number which is:1-800-435-7732. The hours are Monday-Friday 9:00 a.m. - 8:00pm EST and Saturday / Sunday 10:00 a.m. - 8:00 p.m. The reason it does this is because it is a lithium battery and they have a short battery life. If you tell them you have had your camera over a year they will charge you for a new battery but if you have had it less then a year they will send you a new battery for free. I have already gone through 3 batteries in 2 years it is ridiculous!
Posted on Apr 19, 2009
Anonymous
SOURCE: Cannot charge battery
Hola!!!!!
i had exactly the same problem!!!. I bought my exilim Z77 camera in america almost 8 months ago and on my 5 month i charged the battery and it seemed never to charge completelly. The red light of the charger was blinking all the time. I called customer service and they replaced the batery. This is totally free if u are on the year warantee.So yeah ... the problem is the batery not the charger
hope this can help
:D
Posted on May 21, 2009
Anonymous
SOURCE: ROM in Casio E-200 appears to have been erased in updating
my phone wonk let me use my t-mobile sim card and its an vigin phone! help me please?
Posted on Dec 12, 2009
Keyboard will not turn on
If it hasn\'t been dropped or bumped, check the adapter. Work backwards from the keyboard. It doesn\'t take much for the casio adapters to pack a sad. If there\'s an overload in your switchboard, it\'s usually the Casio that packs a sad...everything else is fine, microwave, tv, stereo - just not the casio. Their adapters are garbage and until recently - they\'ve just gotten better
Oct 02, 2013 • Casio Music
My casio rock wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Alright so i wanted to know if i can charge my Casio Exilim Zoom EX-Z700 Digital Camera without the actual charger but just plug it into my computer and it'll charger that way. i've tried this...
No. You need to plug the camera into the cradle and plug the cradle into a wall outlet. Connecting the camera to the computer merely drains the battery faster, as the camera has to spend juice communicating (or trying to communicate) with the computer, even if only to say it has nothing to say.
Battery
You eather have a bad battery or charger. you can goto wolf camera and see if the battery will charge on their charger or you can goto ebay and get them both for pretty cheap. heres one combo on ebay.
http://cgi.ebay.com/Charger-Battery-For-Casio-NP-40-EX-Z750-Z57-Z50-Z1000_W0QQitemZ330225857192QQihZ014QQcategoryZ50510QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Won't turn on
I've seen a lot of Casio chargers go bad, not charge the battery, and then this is what happens. I've been using an aftermarket charger and battery I got off eBay, and they work great. I've even used the aftermarket charger to "revive" batteries that the Casio charger wouldn't charge up.
9answers
Battery/charger problem
Is your charger plugged into a power strip?  Try plugging it into the wall instead.  It worked for me.  It just blinked a few times then it began charging!
2helpful
4answers
When charger is plugged, amber light blinks once and then nothing? E125 not working at all!
The Casio PDAs will quit charging very quickly if the battery is very, very discharged. If you continue to remove and re-insert the charger into the PDA's power socket, the recharging cycle will last longer and longer until finally the stupid thing will fully recharge its battery.
I have two Casio PDA's and three batteries that were recovered after a bit of tedious struggle to force the charging cycle to complete.
Top Casio Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
