Atx motherboard wiring diagram - Computers & Internet
Posted by AGRIS JUBASS on
  • AGRIS JUBASS Sep 30, 2011
    i nead wiring power swich,reset swich,h.d.d led pover led, basicly all front panel
joecoolvette
  • 5,660 Answers
For the power cables from the Power Supply? Or Power Supply, and Front Panel header on the motherboard?
For both of these you need to state the computer manufacturer name, and Model Number.
Post back in a Comment.
If you just wish a generic, one-size-fits-all explanation;
A) 20 or 24-pin ATX main power cable.
The older computers use a 20-pin ATX main power cable. As computers needed more power to the motherboard, the 24-pin ATX main power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll the page down for info on the 24-pin ATX main power cable.
[ Much older motherboards (AT) used two main power cables. { In the link - Original PC main power cables} ]
B) 4-pin ATX +12 Volt power cable.
Was brought out because Processors needed more power, than the 24-pin ATX main power cable feeding the motherboard, could deliver.
Power for the Processor,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) 4-pin standard Peripheral power cable
Commonly misnomered as 'Molex'.
Molex was a model name given by the first manufacturer, of this design of power cable connector.
The name stuck. Kind of like referring to an adjustable open-end wrench as a Crescent wrench.
It is also referred to as a 4-pin Standard Peripheral power cable, because there are two styles of 4-pin Peripheral power cables.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Generally used for IDE (PATA) harddrives, and IDE optical drives.
4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Older computers used it for power to the Floppy Drive. It's generally used now to provide power for a Card Reader.
Note that both types of connectors use the same power wires, and 2 ground wires.
Yellow is 12 Volts
Red is 5 Volts
Black is Ground
[ Also, in the ATX main power cable:
Orange is 3.3 Volts, the Green wire is the Soft Power On wire. Abbreviated as PS_ON.
Power Supply plugged into power, the Soft Power On wire is briefly touched to ANY Ground wire. This is bypassing the Power On switch.
If the computer (Power Supply) comes on, you have a bad Power On switch.
IF the computer (Power Supply) does NOT come on, you have a bad Power Supply ]
(ALL Black wires are Ground wires. They all lead back to one central Ground point.
ALL power wires lead back to one point in the power supply, for EACH power wire.
The 12 Volt power wires, (Yellow), all lead back to one point in the Power Supply.
This is the 12 Volt power rail.
The 5 Volt power wires, (Red), all lead back to one point in the Power Supply.
This is the 5 Volt power rail.
The 3.3 Volt power wires, (Orange), all lead back to one point in the Power Supply.
This is the 3.3 Volt power rail ]
D) SATA power cable
15-pin power cable for SATA harddrives, and SATA optical drives,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ The smaller 7-pin SATA connector is the interface cable, or data cable.
IF, you have a SATA harddrive that has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
It will burn out the harddrive if you use both. It may not do it right away, but eventually it will.
I have had people state over the years, that they were using both power cables. Came back two months later to tell me their harddrives had burned out ]
More to follow in a Comment.
Regards,
joecoolvette
Posted on Sep 30, 2011
  • joecoolvette
    joecoolvette Oct 01, 2011
    POST in a Comment the computer manufacturer's name and Model Number, or the motherboard manufacturer's name and Model Number.
  • joecoolvette
    joecoolvette Oct 04, 2011
    Wait a minute! Hold the phone!
    You want a detailed Front Panel Header pinout, yet you are not willing to post the Manufacturer
    Name and Model Number, and you give ME a 2 thumbs up rating? Sheesh! The nerve of some people!
1 Related Answer
Rahul C
  • 89 Answers
SOURCE: Where do i connect the
Hi, The SW wires are connected on pins just below SATA connectors.The details of what pin corresponds to what will be given in your Motherboard's user-manual. Thanks, C Rahul
Posted on Jul 20, 2011
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
How to make a pc power unit work without a motherboard?
There are two pins on the atx connector you need to bridge. You can wire a switch to the pins too if you want so you can toggle on and off. Otherwise, there is a guy on eBay (seller id: antronst) that sells a connector with the pins already bridged with a on/off switch and a resistor wired in to provide some stability for five or six dollars.
Here is a diagram. Make sure it is a standard atx power supply. Some old Dells had goofy wiring.
http://www.techpowerup.com/articles/other/22
May 16, 2014 | Intel Acbel Power Supply Supports ATX 12V...
I need a wiring diagram for a vt8233a motherboard
http://www.manualslib.com/manual/396728/Jetway-V333dar2a.html
Sep 19, 2013 | Jetway V333DA VIA KT333/VT8233A Socket A...
Power supply diagram for ht 2000 motherboard
http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Regards,
joecoolvette
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
Where do i connect the sw wires on a packard bell imedia micro atx motherboard. Diagrams and written adive would be appreciated.
Jul 20, 2011 | Packard Bell (181402) Motherboard
Need pin out diagram to see what wires are power
http://pinouts.ru/Power/atxpower_pinout.shtml
Bingo. This is the pinout for the standard ATX power connector found on motherboards.
:3
Jan 06, 2011 | Computers & Internet
Cables not connected for power, hdd light another
http://www.tomshardware.com/forum/261599-30-8istx-wiring-power-switch
Jul 23, 2009 | Intel D845GVSR Motherboard
I need a diagram of the atx pwr connector for an ASUS P4V8X-MX
If you mean power to the devices themselves, the 4-pin connectors coming from the power supply plug in to the drives. The red wire is +5 volts, the yellow wire is +12 volts and the black wires are ground (earthing) connections. IDE hard drives and CD drives use the same connector. SATA drives may have that same connector as well, but most use a different style. SATA-ready power supplies will have 1 or more plugs available. Adapters to switch from the 4-pin IDE plug to SATA type are available for supplies that don't have the right connector.
If you are asking what power pins from the mainboard power supply connector are supplying power to specific controller parts on the mainboard, that kind of detailed information is not available. Mainboards manufacturers do not supply circuit diagrams or repair information. They simply replace any boards that fail while still covered by the warranty, and expect you wil just buy a new one if the warranty has expired.
Much information about ATX boards including the power supply cable pins is found here:
http://en.wikipedia.org/wiki/ATX
Feb 09, 2009 | ASUS P4V8X-MX Motherboard
Install
for what front coneters to mobo for power rest ect ?>
Jan 19, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Computers & Internet Logo
1,673 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
