It isnt the door lock or it would not work on the first 2 spin cycles and unless you have huge out of balance loads the door(not lid as lids are only on top loaders) interlock probably isn't at fault. i would cleanout the tub to pump trap inspect the pump for blockage and flush the discharge hose. it doesn't cost a penny to do this and has fixed many front loaders with the same problem
SOURCE: G.E front load washer Mo# wbvh6240fww
The door interlock may be faulty. Try closing the door firmly or hit the door handle when the door is closed.
SOURCE: front load washer
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
SOURCE: doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
SOURCE: GE WVSR1060A1WW washer will wash but will not drain/spin
Lid Switch either magnetic or mechanical
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
