Question about Krups KM7000
This is the Krups Grind and Blue Coffee Maker purchased from Amazon 7/8/11. It is the second one I purchased. Krups factory service AND local service station phone lines are constantly busy. On this unit, the "D" - Brew Basket Cover has jamed in the closed position and will not release with the "H" Brew Basket Cover Release (reference: Krups Manual). There is a screw accessible at the top of Brew Basket Cover. Krups on-line materilas do not address fixing (Ior releasing) this jam. Thank you in advance for any advice you can give.
Posted by Neil Wasserman on
  • Neil Wasserman Sep 30, 2011
    Sorry, that should read: KRUPS GRIND AND BREW MODEL KM7000 10 cup Coffeemaker
Dcramer531
    President:
  • 1,654 Answers
Sorry for the delay. I will need to look up some reference materials and drawings on this before I can aupply an acurate answer. Been one of those nights and I apoligize for the delay.
Posted on Oct 01, 2011
  • 4 more comments
  • Dcramer531
    Dcramer531 Oct 01, 2011
    Still trying to get some reference materials but Keurig is not very helpful on their materials. The Keurig coffee making machine is not assembled with disassembly of the Keurig in mind. They are very difficult to take apart and even harder to fix. In the mean time try backing that screw off just a little bit to see if this helps releas the cover and keep trying the release as it may be out of alignment. This is not one of thier common issues as I can find liitle on this type of problem and have not seen this myself. Most times when a cover gets jammed there is an alignment orbinding issue.
  • Dcramer531
    I just realized I have been looking and calling your machine Keurig and now have found some references and tips on the Krups. These machine use tamper proof screw in a triangle shape which are not easy to come by. If you have an old screwdriver you can file down to fit in the slot is cheaper than buying a bit ot scredriver for this. Still have not found a solution to the jamming issue and I am still sure there is either a broken release or alignment problem. I will get more for you shortly
  • Dcramer531
    After reviewing the drawings I need you to try and use the return lever C awhile gently twisting and rocking the brew basket along with wiggling and depressing the release lever. Something must be binding or the release lever is either broken or bent. Also check from above in the coffee chute to see if something has come loose and fallen in the basket. I will get back with you after reading more and seeing if this has happened before.
  • Dcramer531
    Is there any way your filter basket was not inserted correctly and did you have to force the cover closed. If the basket is not inserted correctly the lid will not close. If this was miss aligned then the cover can get jammed.
  • Neil Wasserman Oct 01, 2011
    Hi Again:
    I worked on the Krups for quite a while this morning, carefully following your suggestions. Unfortunately it remained tightly jammed. I then removed the screw in the center of cover -- it has been changed to a regular fillips-head screw. Inside were some very flimsy metal pieces that had been misaligned and another screw loosened. I carefully fixed these and reassembled. It was still jammed. It appears to be a problem with the connection between the side release and the top, which no longer exists. Based on this, I will have to send it back to the Krups Service Station. It makes great coffee but is very flimsy in construction. I believe this unit is not repairable but will have to be "replaced". I regret purchasing another one and I will leave a warning on Amazon to avoid this model/product.. Your assistance was very helpful and well worth the price. Thanks again. NHW
  • Dcramer531
    Dcramer531 Oct 02, 2011
    Thanks for the information and I do feel sorry that this can't be fixed but most of todays coffe makers are quite frankly junk. The Kuerig which I was focused on to start is a major headach as well and these just aren't made to last, if you saw how they are made inside you would laugh at how cheaply they are put together and then wonder why people get upset. Most makers of these machines have a very liberal return policy because so many get returned. I have gone back to the old standard coffe makers becuase they hold up so much better. Bunn is an excellant machine especially thier comercial machines they seem to last forever. If there is any thing else I can help with please feel free to ask.
    Thanks for using our service.
    Dave
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Where can I get a thermal fuse harness for a Krups mk7000
If it is no longer available why not read the temperature rating on your dead fuse and replace the fuse only?
Aug 18, 2014 | Krups KM7000 10 cup Grind and Brew coffee...
Krups K2 XP402040 Expresso maker. This makes the
Would you like to try not put too much coffee powder, and not make the coffee powder too firm ( I mean not press them too heavy.)
Or, not grind the coffee powder too thin....
Hope it helps you.
Oct 30, 2009 | Krups Coffee Makers & Espresso Machines
Can't find replacement for rowenta carafe..glass
  1. Rowenta Official Storewww.ShopRowenta.com Full Line of Rowenta Irons Get Your Rowenta Direct!
  2. Rowenta Irons & PartsSmallAppliance.com Shop the full Rowenta Line. Irons, Parts & Accessories.
  3. Rowenta Sale, Ships Freerowenta.irawoods.com Premium German Irons & Steamers Ira Wood est. 1918. Houseware store
Search Results Rowenta coffee pot replacements Coffee Maker Accessories at ... Compare prices on Rowenta coffee pot replacements Coffee Maker Accessories. Find store ratings & read consumer reviews on Krups Coffee Maker Accessories.
www.bizrate.com/coffeemakeraccessories/products__keyword--rowenta+coffee+pot+replacements.html - 120k - Cached - Similar pages
OR TRY EBAY!
Jun 03, 2009 | Rowenta Krups& Programable Coffeemaker...
Instructions manuel
Eureka! I found the manual on Amazaon.com on a posting for the Krups Gusto espresso maker
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052280.pdf
Jul 20, 2008 | Krups Gusto 880-42 Espresso Machine
Krups KM7000 Logo
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
