Question about Samsung LTM1775W 17 in. LCD Television
Remote 00224B for samsung ltm1775w not working. Already tried changing the batteries, but problem remains. Other Samsung remote works with TV, so the problem is the remote. Remote was stored for a long time, without any use.
  • Samsung Master
  • 17,130 Answers
Possible that the battery had leaked and so there is damage on the board. You will need to check if there is IR emission to confirm.
please check the link for tips :
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Posted on Oct 01, 2011
6ya staff
SOURCE:
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
My remote Not working,
If your remote is the Samsung one for your TV, it is already programmed. Check to be sure the remote was not stored with batteries in it and try installing new batteries
Jan 08, 2013 | Samsung LE Televison & Video
Samsung DVD Remote contol: Cannot change over from TV to DVD. DVD Receiver/TV button remains on TV.
Hello, take the batterys out wait 15 minutes and put it back it will work if not change the batteries.
success!
Apr 03, 2011 | Samsung Televison & Video
Hello,i have samsung 13" tv
The original remote has an infrared sensor that you point to the tv "looks like a led except it see through" it has become defective and must be changed, some service shops may carry some, also try Radio Shack.
Feb 06, 2011 | Samsung TXJ1366 13" TV
Bad Remote
try this: 1. change the batteries in the remote, 2 make sure the terminals inside the remote are clean, 3. if possible try opening the remote there my be some damages inside the remote, 4 borrow the same remote to a near friend to see if i works with your Tv, if it works then you need to repair yours all buy a new one
Jun 25, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
Samsung LTM1775W 17 in. LCD Television Logo
Jerry Greenberg
Jerry Greenberg
Ekse
