Dewalt DW703 10"  Compound Miter Saw Logo
Anonymous Posted on Sep 30, 2011
What's your problem? I HAVE A DW703 MITER SAW WITH NO MANUAL. I DISASSEMBLED THE SAW GUARD AND NOW AM UNABLE TO PUT IT BACK TOGETHER.
Level 3:
  • Dewalt Master 6,687 Answers
  • Posted on Sep 30, 2011
Cindy  Wells
Dewalt Master
Level 3:
Answers
6687
Questions
0
Helped
3529581
Points
21743
Check the plaque with the model and serial number for the Miter Saw Type. This will be below the model number. There are two types for the DW703 miter saw (1 and 3). Dewalt has exploded parts diagrams and the instruction manuals for the saw on their support site: http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW703&selectedType=6139 . The differences between the two types may be critical so use the drop down menu below the model number to select the type of saw before looking at the diagram. The manual and parts diagrams are on the right under Downloads. You will need to scroll down for the manual. Unfortunately a few of the part numbers are cut off at the top of the exploded parts diagram.
I hope the diagram helps you reassemble the guard. I've never taken the guard off so I'm not sure of how it fits together.
Poul Brinchs Larsen
Level 2:
Sergeant:
  • Expert 159 Answers
Poul Brinchs Larsen
Expert
Level 2:
Sergeant:
Answers
159
Questions
0
Helped
49513
Points
511
I don't know if the manual will help you put your saw back together, but here it is in pdf :
http://c.shld.net/assets/own/00923410e.pdf
Good luck and Regards
Ryobi TSS100L blade guard spring
I think what you are refering to is a circlip washer , and can only be
fitted with ( CIRCLIP PLIERS ) do you know any Michanics or Engineers as they are bound to have a set in their toolbox ,on the other hand you
can buy them. What they do is work in the opposit way normal pliers do
when you squees the handles together the jaws open,therefor opening
the (CIRCLIP ) and allowing you to place it over the pin and into the
recess. Hope this has been of some hellp goodluck T.C.
11helpful
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
1helpful
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
How do I unlach it for use?
pull the pin on the back of the saw
1helpful
How do i change the blade on a bosch 3912 chop saw
Push the saw down and manually hold the guard while it is the retracted position and let up on saw while holding guard,you should
be able to put in wrench and loosen bolt.
Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Top Dewalt Saws Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
