Question about Microsoft Excel 2010
Insert a calculated field named % Change in Value to determine the percent change in values by type in Excel?
Anonymous
    New Friend:
If field A1 is the old value and A2 is the new value, then the formula for A3 (% change) is:=(A2-A1)/A1*100You can remove the *100 if you want to format the field to the Percent type.
Posted on Oct 11, 2011
How to figure percentage of increase
Percent change =100%*(new value- old value)/(old value)
If result is positive it is an increase, Otherwise it is a decrease.
May 02, 2014 | Casio ClassPad 300 Calculator
What percent increase is 251 to 322
Percent change = 100 % * (new value- old value)/(old value)
Mar 28, 2014 | Office Equipment & Supplies
Percent of increase
change =(new value-old value)/(old value)
Percent change =change*100 %
change=(8900.00-8640.00)/8640.00=0.0301
Percent change=0.0301*100%=3.01%
Since the change is positive, the new value is higher than the old value, this change is an increase.
Percent increase=3.01 %
Mar 05, 2014 | Office Equipment & Supplies
How do i calculate a difference in a percent?
If the value in A1 is 100, and the value of A2 is 120, then the formula =(A2/A1)-1 will return 0.2. If the cell containing the formula is then formatted to display as percentage it will show as 20%.
Dec 13, 2013 | Microsoft Excel for PC
Insert a calculated field named % Change in Value to determine the percent change in values by type.
Assuming that the Original Value is in cell A1, and the New Value is in cell B1, then the formula for % Change pin Value is =(B1/A1)-1.Format the value in % style and you're done.Rgds,Scott
Sep 30, 2011 | Microsoft Excel for PC
How to calcolate %
Inputting a value and pressing SHIFT [%] converts the input value to a percent. For example:
2 SHIFT [%] = produces .02
To determine 20% of 150:
150 * 20 SHIFT [%] = produces 30
To calculate what percentage of 880 is 660:
660 / 880 SHIFT [%] = produces 75
To increase 2500 by 15%:
2500 + 2500*15 SHIFT [%] = or
2500 * (1+15 SHIFT [%] ) = produces 2875
To discount 3500 by 25%:
3500 - 3500 * SHIFT [%] = or
3500 * (1-15 SHIFT [%]) = produces 2625
To calculate the percentage change from 40 to 46:
(46 - 40) / 40 SHIFT [%] produces 15
Sep 11, 2010 | Casio FX-115ES Scientific Calculator
Steps to figure out formulas in excel
Hello this is Baris,
If you forget about the numbers and start naming your cells you can figure out your own formulas... Example :)
You buy apples, and you pay $2 per piece
in this case you have 2 numbers to find out how much you will pay.
price per apple
quantity
you have 3 apples you pay 6 dollars very simple right. 2 times 3.
Same thing in excel but this time you will just say price times quantity and excel will do the calculation for you.
Lets name your cells
Type in A1 Price
Type in B1 Quantity
Type in C1 Cost
Now, Column C is your calculation area.
Type in A2 2 (price for apples)
Type in B2 3 (quantity of apples)
Type in C2 =A2*C2 (price times quantity)
Now on, you don't have to calculate anything. You can change you price and quantity, cost will change by itself. Because the value in that cell is now related to other values in A2 and B2. I hope this gives you a starting point.
Sep 30, 2009 | Microsoft Excel for PC
1. calculation for excel spreadsheet macro for calculating the a right angle triangles hypotinuse and opposite side, angle given
First off all when you say hypotinuse I think it is a 90 Degree triangle. Total of the angles off a triangle is 180 degree. So it is a simple algebra question.
Hypotinuse is 90
Right angle is R
Left angle is L
Total is 180
Equation is 90+ R +L = 180
We are looking for R, so lets arrange our equation.
R= 180 - 90 - L
R= 90 - L
This is our formula for excel
Lets put it in the excel
Type in A1 "hypotinuse "
Type in A2 "Left Angle"
Type in A3 "Right Angle"
Type in B1 90
Type in B2 "whatever the value given for the left angle"
Type in B3 =90-B2
As soon as you change the value in the cell B2, B3 will change by itself. Hope this helps :)
Sep 27, 2009 | Microsoft Excel for PC
When I enter a formula in a cell with the the insert functon device, it does not calculate itself, but shows as text
Is there by any chance a space or any other character before the equals sign? That could cause your formula to display as text.
Dec 03, 2007 | Microsoft Excel for PC
Microsoft Excel 2010 Logo
Top Microsoft Computers & Internet Experts
efs_perpends
efs_perpends
k24674
Jax Planet
Jax Planet
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
