Question about Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA CUTTER
How to change from 115volt to 220 volt on lincoln 25 plasma cutter
Posted by James Davis on
Robert Smith
    Sergeant:
  • 243 Answers
There should be a electrical board in the rear under a cover. There are different configureation of some jumpers that can be changed. The diagram should be inside the cover.
Posted on Sep 30, 2011
How do I wire the plug to a Lotos plasma cutter for 220 volt ?
There are three wires on the machine, RED BLUE and YELLOW GREEN. In a standard US 220 VAC connection there is red, black and white. RED is connected to red, BLUE is connected to black and YELLOW GREEN is connected to white.
Sep 12, 2014 | Lotos LT5000D 50-Amp Plasma Cutter
I have a pro cut 25 i would like to change it from 110v to 220v
The pro cut 25 will run on ether 110v or 220v without changing anything. I made a 220v to 110v adapter. It works well and if I want to run it on 110v it will still plug right in.
Dec 05, 2013 | Lincoln Electric Plasma Cutter, Pro - Cut...
Want to change from 110v to 220v
There is a small red switch on the back that you can use to switch it.
Need 2 capacitors for my plasma cutter 1500uf 240v
Hi, can you send me pictures of the caps, all sides. And also next to a tape measure if possible.
Regards
Jun 02, 2012 | Lincoln Electric Plasma Cutter, Pro - Cut...
What kind of air compressor do you need to run a plasma cutter? (how many psi, gallons, volts... and any other info...?)
Hi:
You will need at least the following:
25 CFH at 120 PSI
30 gallon reserve tank
220 V single or 3 Phase (that depends of your voltage available at your shop/home)
For cutting: set your plasma regulator to 75 psi.
For Gouging: set your plasma regulator to 65 psi.
That's all.
Aug 02, 2011 | Lincoln Welding Tools
How do u change from 110 to 220 volts. Do u just
There should be a wiring diagram label on the inside cover that tells you where to connect the leads for 220 volt operation. I assume you do not have the manual, so you can also call 1-800-332-3281 for Hobart assistance and a manual.
Jul 21, 2010 | Airforce HOBART AIRFORCE 400 PLASMA CUTTER...
Setting for welding aluminum
You have posted under a plasma cutter. These CANNOT weld metal, only CUT it.
Jun 04, 2010 | Lincoln Electric Century Portable Plasma...
Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA CUTTER Logo
231 people viewed this question
Top Lincoln Welding Tools Experts
David Soto
David Soto
ROB
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
