Question about RCA D52W19 52" Rear Projection Television
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse over the last couple of months and now the tv will not stay on. Chassis no. is ITC222. Thanks, Aaron
Jdvillanueva
  • RCA Master
  • 2,098 Answers
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Posted on Sep 30, 2011
  • 4 more comments
  • Anonymous Oct 02, 2011
    Hi Jay,
    Previously it took a few times of pressing the power button before the TV stays on. Now it does not turn on at all using this strategy. The last time I got the tv to stay powered on was after I unplugged it from the electrical receptical for a couple of hours. I am thinking a capacitor is not discharging or something. I hope you have a cheap solution! I have a soldering iron and am pretty handy..
    I look forward to your reply.
    Aaron
  • Jdvillanueva
    Jdvillanueva Oct 02, 2011
    Thanks for the response.
    This kind of symptoms is an indication of out-of-regulation condition in the power supply section. This is caused by faulty electrolytic capacitor like what you've suspected.
    Leaky electrolytic capacitor has a physical indication of fault like bulged/dome at the top and can be easily identify through visual inspection. Watch this link
    http://www.youtube.com/watch?v=oDGjWOabJ...
  • Jdvillanueva
    If you found them on the power supply section, replaced it with same capacitance and working voltage that is printed on its body itself. Watch this video for more info regarding electrolytic capacitor.
    http://www.youtube.com/watch?v=YCSNWi3UH...
  • Jdvillanueva
    Dried electrolytic capacitor has no physical indication of fault, you must have a capacitor checker/tester to determine its condition and pinpoint the faulty one. If not available, you may replaced all electrolytic capacitor except the largest capacitor. It will not cost you much because this is one of the cheapest part on that board, cost only $0.5 to $4 at the most.
  • Anonymous Oct 04, 2011
    Hi Jay,
    I need a bit more info.. Where in relation to the back panel is the power supply section.. Should I assume it is behind the panel with the electrical power cord..or is that too simple??
    Please advise.
    Thanks,
    Aaron
  • Jdvillanueva
    Jdvillanueva Oct 04, 2011
    Yes, the power supply section is where the power cord's directly connected. Unplug the unit for 1 hour to drain any voltages from the power supply before you repair it...
I HAVE A 52' RCA HDTV THAT WILL NOT TURN ON ,AT TIMES IT SEEMS LIKE IT WILL TURN ON BUT THEN GOES BACK OFF,CAN ANY ONE TELL ME WHAT THIS PROBLEM CAN BE
sounds like the power caps CP150 CP120 and CP114 on the deflection board. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit also comes with instructions.
Mar 15, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 55 inch projection hdtv and it wont come on!!! when i push the on button the lite comes on but no picture and no sound and then it goes back off... its then tries to power back on by itself...
Suspect your POWER SUPPLY. Either your supply is faulty OR something else in your TV is demanding too much CURRENT (from the supply) and your supply may be 'protecting itself' with 'emergency shutdowns'.
These links and PHOTO WILL help you ~ if you are serious about repairs!
I know it's not quite the same model number as yours, but the steps and efforts remain similar.
RCA TV repair 52 HDTV
Recent Questions Troubleshooting Support for RCA D52W19 52 Rear Projection...
Finally, this REAL 'old puppy' that DEMANDS LOTS of AC POWER to fire-up your 3 'super-bright' projector lamps inside! Are you sure you won't consider pushing this TV to the curb instead of investing HOURS of your life to fix this one?
I'm confident you have spent LOTS MORE on your POWER BILL (over the years) than the cost of a NEW Flat Screen model! GO ahead ~ you deserve a quality TV... but stick to known brands like LG - VIZIO and Panasonic to avoid the "no parts/boards available" problem (way down the road).
*(Your TV is so old that the Internet has NO CLUE when they first made this model)*? Also I see a whole ARRAY of problems with this series and it's no surprise that yours has similar problems!
Anthony
Jan 29, 2018 | RCA D52W19 52" Rear Projection Television
My tv wont stay turned on. It comes on then turn of comes on the turns off
I press the power button it blinks green and attempts to come on three times but it never comes on
Aug 27, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV - problem turning on
It's on but you are on the wrong input. check your connections from your sources ( i.e. dvd, vcr or satellite/cable box) try pressing source or input button on tv remote
Jul 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA Scenium 61" DLP tv. Recently when you attempt to turn it on, it turns back off and the power button blinks three times. Then the tv will continuously attempt to turn itself back on with the...
sounds like you need to replace the color wheel but most of the time that is almost as expensive as the TV itself best bet for this problem would be to bring it to a shop and have it serviced
Mar 27, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Problems powering up
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Dec 13, 2008 | RCA D52W19 52" Rear Projection Television
RCA Mode D52w19 Makes humming noise wont come on
unplug
short in tv or break....call uno who$$$$$$$$$$$$$$$$$$$$$$$we luv it
Aug 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
