Dacor PCOR30 Convection/Microwave Oven Logo
Anonymous Posted on Sep 29, 2011
Unit shuts down every 59 sec. No matter how much time, with or without anything in micro and I figure to replace motor and switch. How do I get to those parts in unit? Does it have to come down?
William Miller
Level 3:
  • Dacor Master 9,179 Answers
  • Posted on Nov 26, 2011
William Miller
Dacor Master
Level 3:
Answers
9179
Questions
Helped
4480967
Points
21747
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Dacor-branded PCOR30-series microwaves are just cosmetically altered versions of the Sharp R1870-series ovens.
These Sharp-made models stop after 59 seconds when there's damper toruble.
See the attached sample drawing below for a typical damper assembly.
We have the applicable service manuals for the Sharp models and have uploaded it to our site here and here to help you in disassembling and troubleshooting your Dacor version.
You can find the Dacor PCOR parts list here and you can order Dacor parts by part number here.
If a switch is all you need, we offer a universal type for only $7.50 postpaid which you can order here.
You will have to remove the oven from the wall and remove the outer cover to access, test & replace damper parts.
Just refer to your installation instructions.
If for some reason you don't still have yours, scroll down to the bottom of this page to find yours.
10helpful
My Sharp micro will stay on for 59 seconds and shut off no matter how long the timmer is set. Sharp model r 1870 It does this every time it is used . The control board has been replaced.
This is not a problem on the board, it is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded them to our site here and here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
11helpful
Stops every 59 sec.
Sharp models stop after 59 seconds. That's the giveaway.
We have the applicable service manuals for some of these models and have uploaded them to our site here and here to help you.
Hopefully these cover your model number, which you didn't mention.
William E. Miller
[email protected]
http://www.microwavedisplay.com
1helpful
R-1874 shuts down after 59 seconds
That switch is supposed to tell the computer if the damper door is open or closed. If it does not go to zero ohms, the CPU doesn't know what to do. Check the thermistor too...... just in case...
2helpful
No matter what time i put in it cuts off in 60 seconds on a sharp
This sounds like a bad damper switch or motor. Double check the shut off time....... see if it's actually 59 seconds..
When you unplug the unit from the wall for 2 minutes then plug it bad in, you should be able to faintly hear a motor run for a few seconds. This is the damper motor running. This will verify that the motor is operating.....
Also, check the thermistor.
Sharp r96st stops at 1 sec and halts whilst preheating oven
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
3helpful
59 SEC NEED TO GET FRONT OFF MICRO
If your unit runs for 59 seconds then stops, the problem is the convection damper motor. (Sharp part # RMOTDA222WREZ).
Unfortunately, you cannot access this from the front - the whole unit has to come down as the entire outside cover has to be removed.
This is a pretty major job and the motor (located below and behind the magnetron tube) is rather hard to remove and get back into place. This is probably better left to an experienced technician. You can call Sharp 1-800-BE SHARP for a referral to an authorized servicer.
Will shut off in all modes after 59 seconds. will keep countdown time when shuts off, restart and will start and continue count down time for another 59 sec only. voltage good. unpluged repluged. makes no...
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
We're happy to help and we appreciate your thoughtful rating of our answer.
1helpful
4answers
Unit runs for 59 seconds and shuts off
This is a problem in one of the damper-related components, most likely the switch or motor, but it may also be the motor or the damper door.
The damper is a door located on the right side of the innards. The damper closes and opens depending on cooking mode.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
You can find a helpful exploded view by entering your model number here: http://www3.sears.com
20helpful
4answers
Sharp R-1874 shuts off after 59 seconds
I had the same problem. Turned out to be the micro switch and damper motor. I replaced both myself and fixed the problem for less than $40.00. The best advice I got was replace the switch, reconnect the motor and make sure the motor runs through a damper door cycle. It didn't run, even though it showed continuity and had power, so I replaced the motor which solved the problem. The micro switch which is activated by the cam on the damper motor has to be cycled within one minute, or the unit shuts itself off. The damper motor on my model R-1870 is found in the right rear section of the assembly when facing it. You have to remove the unit, and remove the outer casing to get to it. The damper is a simple sheet metal door, activated by the motor, and the switch mounts at the top of the motor and is activated by the same cam that activates the door.
5answers
Shuts down after 59 sec
Chances are you have a bad damper switch or wiring. A sample photo is here: http://207.234.249.73/mwd/damper.jpg It might also be a problem with the humidity sensor or a problem with the control panel, such as corrupted code or bad connections.
Top Dacor Microwave Ovens Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
