SOURCE: pioneer
turn the HU off...hold down the source button for a couple of seconds and the screen will pop up with the time on it...easy to change from there with the "left, right, up, down" buttons surrounding the source button.
SOURCE: setting clock on my pioneer deh 1400
the radio must be turned off with the ignition key in the on position... then hold the function key for about 3 seconds if it doesnt have the function key try the audio or source button one of them will bring you to a menu, once in that menu use the func key to scroll though options until you see the clock flashing.. use the up down left right keys to adjust these different options...
SOURCE: pioneer cd radio deh-11 clock set
For most Pioneer single CD players, you can set the clock using the following steps:
SOURCE: how do i set the clock on the pioneer deh-p6200bt unit
Clock set (setting the clock)
1 PressM.C.todisplaythesettingmode. 2 PressM.C.toselectthesegmentoftheclockdis
play you wish to set. Hour Minute As you select segments of the clock display, the selected segment flashes.
3 TurnM.C.toadjusttheclock.
