Question about FixYa Service
Log on to FixYacom Call 1-8O5-465-751O Support Number
Anonymous
To sign into Fixya, just visit any page on the website and click the sign in link in the top right corner of the page.
Hope that helps!
Posted on Aug 20, 2014
2answers
Www.fixyacom/cars/t5090137-ve_got_2007 Saturn ion water leaks from air conditioner onto assenger floor. how to stop it?
remove glove box and plastic ducting by fan will be the ac coil also a little drain with a tube that runs into engine by firewall or to fender and down to drain condensation ur drain is clogged [if u can c or access the drain tube from outside clear with air first ] but clean drain and clear tube
Fixyacom manuals
did anything spill on your drivers front window switch? or rain...
My AX3910-U2032 ASPIRE Acer require a log in pin number. I want to log in without pin number. How to do it.
pin number? as in a wireless account? does not sound like a computer log in request
please verify log in screen description and re post
2helpful
2answers
How to fix error mesage on TI-30Xa. Every time I press LOG an error sign comes up. how do i fix this?
To take the log of a number, enter the number then press the LOG button, then the =. To take the log of a negative number, enter the negative number using the +/- key just to the right of the decimal point. To calculate the negative of a log, calculate the log and then negate it using +/-. To calculate the antilog (inverse logarithm), press 2nd then LOG.
Bear in mind that LOG is the common (base-10) logarithm. For the natural (base-e) logarithm, use the LN key to its right.
I am having trouble figuring out how to enter problems to find logarithmic functions
Let me give you a general recipe to familiarize yourself with any calculator, if you are averse to reading the manuals.
Most function will work in one of two ways.
1st way
Enter the number, then press the key,; the result is displayed.immediately.
Second way
Press the function key ( a left parenthesis may be displayed) enter the number (close the right parenthesis if there was a left one) press the = or EXE or ENTER keys.
Try the two ways described above to calculate the following values. The answers are given. Here log is he decimal logarithm and ln is the natural logarithm.
log(1)=0
ln(1)=0
ln(2)=0.693147181
log(2)=0.301029996
ln(100)=4.605170186
log(10)=1 (= number of zeros after the 1)
log(100)=2. (= number of zeros after the 1)
log(1000)=3 (number of zeros after the 1)
log(10000)=4 (number of zeros after the 1)
How do i use log functions on the HP 39g+. For instance i want to use log10 1000 which should equal 3 or 3^5=243 so log3 243 should equal 5. If i press log the calculator shows: log( If i...
To calculate the common log ( LOG base 10) of a positive number, just press the LOG key, the one above the blue Division key, then enter the number and close the right parenthesis. Press the ENTER key to get the result.
If you want to calculate the log in a base other than e (natural) or 10 (decimal) logarithms, you need to make use of one of the equivalent formulas below
log in base a of a number b
log_a(b)=log_10(b) / [ log_10(a)] or
log_a(b)= ln(b)/ln(a)
3helpful
How to type log base 2
You can't. However, you can calculate the log base 2 of any number by calculating
log2(x) = log(x)/log(2) = ln(x)/ln(2)
That is, the log base 2 of any number is the log of that number divided by the log of 2.
Explain how to find the logarithm, base 18, of a number.
Sorry I clicked the post a clarification request too fast.
You cannot compute it directly. You have to use the formula
log_18(number) = ln(number)/ln(18).
Here log_18 is log in base 18, ln is the natural logarithm (naeperian or log in base e).
Alternatively, you can use
log_18(number) = log(number)/log(18)
where log is log in base 10.
If you use those types of calculations a lot, it might be a good idea to get a Casio FX-115ES, or a Casio FX-991 ES. They have other nice features like fraction calculations and radicals.
Hope it helps.
2helpful
How do i calculate the log of a number?
To calculate the natural log of a number use [LN] key. You enter it as
number [LN] [=] exemple 15.32 [LN] [=] gives 2.729150164
To clculate the log base 10 (common logarithm) you use the [LOG] key
15.32 [LOG][=] gives 1.185258765.
Hope it helps
Open Questions:
See all FixYa Service Questions
FixYa Service Logo
Top FixYa Computers & Internet Experts
Ekse
Rob Hill
Rob Hill
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
