Failure of the sound processor. All you can do is to remove the cover, clean the insides, check the cables to make sure they are still firmly plugged in and then measure the 5 volts power line from the source. If all appears OK the the processor has died - a replacement board is mandatory. It will be cheaper to buy a new receiver .
Sansu rz-8000avd transistor 12N60
What DOES work? Use of analog 6 inputs disables all digital processing and requires the source to provide up to 6 analog RCA channels.
The source is responsible for sending a coherent digital bitstream. What is the source?
You might want to refer to the manuals.
Possible fault in the processing unless there is a signal fault in the input. These are highly packed boards and working from the outside will be difficult.
I think you need to take consensus with the service center that to experiment or tamper.
Test with a different signal source to confirm that it is the fault of the amp. Also try and reset amp as a last resort.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-HT07-Home-Theater-Systems-manual/id/354dj098/t/2/
Plug a device that actually has a 6 channel analog output into the DVD/DVD 6Ch inputs. Configure THAT device to put out 6-channel analog.Select ANALOG 6CH on the remote (page 16).
