Question about Dremel 750 02 Minimite Cordless Rotary Tool
Manual dremel minimite model 750 - Dremel 750 02 Minimite Cordless Rotary Tool
Posted by rick menase on
Technirium
    New Friend:
  • 12 Answers
Did you try to ask the manufacture ? If not get a try here. :)
Posted on Sep 28, 2011
Cordless dremel
you might think im crazy but I just did this and it works so far anyway, I cut open my charger for my dremel 7300 model ,my green charging light stop working aswell , I felt naked without my dremel, so after the fourth day I cut it open and tinkered with it, I unwrapped some of that blue tape that\'s covering the copper spool , forgive my terms I don\'t know the correct name anyway I found a lil clear device connecting two silver wires, I twisted them together by grabbing the clear thing and twist until wires are connected put back together , put a batt in and green light came on and is charging, my charger looks like frankenstien but it works, how long will it last NO IDEA but if it stops ill post it, if you try this I hope it works, I should have videoed myself maybe nextime
Jan 01, 2012 | Dremel 750 02 Minimite Cordless Rotary...
When I turn on my 7.2v minimite the tip spins, but stops when I just hold it with my fingers. I changed the sandpaper on the tip and think maybe I did something wrong, any idea how to fix it?
Hi. Is this a small rotary tool, like a Dremel? If so, I'm afraid it is probably just a weak tool with no torque. Buy a Dremel tool.
Sep 14, 2011 | Drills
I cannot get the chuck to tighten the collet
sounds like u are using the wrong collet in the end of dremel the normally have a couple of different collets try changing it for a tighter one also make sure its in the right way
May 29, 2009 | Dremel 750 02 Minimite Cordless Rotary...
Trouble Changing Attachment
Looking down on the collet end of the dremel, push red button and take pliers and turn locking nut in a counter-clockwise direction.
Oct 03, 2008 | Dremel Mini - Mite Cordless Rotary Tool
Cutting holes
My Dremel 300 came without any instructions, so I had to puzzle out how to use the circle cutter. None of the images I managed to find on the Web or elsewhere were any help. I directed my attention to the "spike" on the circle cutter, and eventually I realized that it was on the wrong (top) side of the cutter--perhaps for safety's sake. When I removed it and positioned it on the bottom side of the cutter, things became clearer. The next thing was to locate the correct cutting edge. I had never used Dremel before, so I didn't recognize the cutting "bit", since it looked like a drill bit. The final problem was how to attach the circle cutter to the Dremel tool. I couldn't see any way of fixing the cutter to the tool. I thought perhaps there was something missing--a connector, perhaps. Eventually I found a reference on the Web to "removing the cap" on the tool. I hadn't noticed a "cap", but when I gave it a turn, it began to unscrew, so I knew I was in business. Finally II tried the attachment out on a piece of scrap timber, I found that it worked. A simple instruction manual would have saved me a lot of time. Also, I now discover that the Dremel 400 would be much more useful than the 300. Dremel don't seem to be very customer friendly. I can access the US site, but the UK and Germany website won't let me in!
Sep 01, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Dremel 750 02 Minimite Cordless Rotary Tool Logo
579 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen
Van Allen
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
