My 32" visionquest plasma tv is snowy
Posted by hopperrob on
franckcon86
    New Friend:
  • 93 Answers
You may need a digital video board ????
Try Discount Merchant for any parts you may need for this model tv our any other
Posted on Sep 28, 2011
What is causing my 70 incn plasma tv to have a lot of snow and two col-lams in center that run half way down screen?
There are so many reasons for this fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Troubleshooting procedure to Plasma TVs are given. Almost all plasma displays will have the similar symptoms, as the internal circuit structure, and functions to all are the same, irrespective of its Brand name.
May 05, 2014 | Hitachi Televison & Video
My bush 42 plasma tv has a snowy picture
Check all the input connections. Snowy picture cane be due to weak input signal.
Mar 09, 2013 | Televison & Video
Visionquest tv needs to be reset without a remote
You don't say what model it is but usually there are power, volume, channel, etc, buttons on the side or the top of the tv. Look well. They try to hide them. This link might help.....
http://www.nokia.com/us-en/support/product/c6-00/userguide/?action=onlineuserguidepagechange&pFile=GUID-7774D2C2-534C-4EAB-9970-BC847B9DB674_FILE001.html
Sep 11, 2012 | Televison & Video
Reset Password?
I had same problem, called visionquest tech support for how to reset the tv:
Using the remote, press source then 2580.
A menu should appear, go to other settings then choose restore default. Select yes.
It worked for me - hope it does for you too!
Jan 09, 2010 | Panasonic TH-50PX75U Plasma HDTV
VisionQuest Van gogh Plasma 32''. The standby light shut down. No power on has possible. I check the 3 fuses inside the TV and all is good. Someone know what is the problem !!!! Tks
Good day sir, your tv or any new tv are now using SMPS or technically called switch mode power supply, a regulator mode that is more efficient than traditional power supply, the down side is that its prone to defects, there are three main parts the Switching element which is the transistor, the oscillator circuit which is usually an IC that controls the frequency of oscillation and the high freqency power transformer that works with the switching transistor. All of these parts are need to be checked to ensure proper operations. SMPS also detects overload, which is caused by faulty parts on your tv, unless that faulty part is not found, it will not start and go on standby mode, worst will always shuts down. Call your dealer on how to go about your tv problem or have it check by a qualified technician.
Nov 03, 2009 | Televison & Video
Snowy with blue and black squares
your va and vs need to be adjusted and if that doesnt fix it then you have a board going bad but still requiers repair or service tech to find out
Jan 14, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Plasma
First of all, I'm not an expert but you might wanna change your cables. Bad and cheap cables are usually the reason for bad and snowy picture. Good luck!
Jun 24, 2008 | Televison & Video
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Ilo 42 inch Plasma TV
I have a Ilo 42 inch Plasma TV and it just stop playing, the power light comes on but the screen don't light up at all
Jul 24, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
