Question about RCA F32450 32" TV
Does not accept any signal Direct TV; DVD; VCR.
Posted by Robin Dill on
3 Related Answers
Anonymous
  • 12 Answers
SOURCE: TRYING TO HOOK UP OLD
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Posted on Oct 16, 2008
Lastoni Wibowo
  • 2246 Answers
SOURCE: We just purchased a Samsung TV, and have been
its like the problem come from your dvd/vcr not from your tv, change with another dvd
Posted on Jan 18, 2011
gopakumarg43
  • 76455 Answers
SOURCE: no sound on the tv
As TV and DVD playing reproduces sound, you have to check TVs tuner function first. Connect the TV to external areal by connecting areal via areal socket. Make an auto-tune function. Refer the user manual about how to make an auto-tune to local on-air program. Make sure that, the TV reproduces picture and sound normally. If it is correct, your TV is perfect in all respect. If not, the tuner to your TV should be replaced with same type and number.
Posted on Jun 21, 2012
No signal to tv when dvd or vcrs is off
Assume no signal u mean no digital tv ?and what looses time and channel?do u recieve tv broadcasts via a box or is it built in?if u can recieve channels via dvd recorder i would assume where ever it gets them from needs to be connected to tv also.u dont say if its hdmi leads.scart or coax rf type.more info please
May 23, 2016 | JVC DR-MV5S DVD Recorder/VCR
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
I cannot get the VCR/DVD to record from my tv. I have a satellite dish. The input from the dish receiver to the tv is HDMI1. The DVD receiver hooks into the AV1 inputs. I can set the timer, but nothing...
I have no direct experience but you should note no recording will take place unless the signal format is suitable/compatible. HDMI is a digital signal and your VCR/DVD will probably require an analogue signal.
A tv processes the digital into analogue but sockets at the back of tv sets tend to be input only. A minority of tv sets have two scart sockets, the second one usually providing an output sound and video of what is playing on the tv at the time.
I believe it is possible to buy a box that will convert digital to analogue or vice-versa.
Nov 16, 2017 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
Hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Rich
Nov 14, 2008 | RCA F32450 32" TV
DVD records a black screen if tv is on standby.
You have tuned the dvd recorders channels? dont forget a recorder dvd/hd/vcr is actually a tv set without its own screen and to record from channels you need to have its on board channels tuned in... what you have been probably doing is using a function on many recorders that records direct tv... what this means is it records the feed back signal through the scart lead of what ever channel your tv is tuned to at the time that is why no tv on = no signal
Sep 24, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Just bought TV and connected with red,white, yellow and s-video connections. screen says NO SIGNAL. I have a satellite dish and dvd/vcr. the dvd/vcr image shows up on tv screen.
* Possible Problem *
It's not clear how you have each of the components connected to the TV, but you do mention that you used the "yellow" and s-video connections. Those are both video connections. The yellow is a "composite video" connection. Many TVs won't accept signals from both the yellow and the s-video connections at the same time. Usually one will override the other.
* Possible Solution *
Make sure the satellite dish is on and (hopefully) on a valid channel. Try disconnecting the s-video and checking the screen. If it didn't work, remove the yellow connection and replace the s-video cable. Check again.
If the problem persists, please explain how the TV, dish and the dvd/vcr devices are connected to each other (audio cables not relevant).
May 15, 2008 | Televison & Video
I can not get a TV signal to work with the Toshiba through coax.
bill24 sorry to be the one to tell ya but you need to go into setup on the tv to setup the channels in the menu and the memory and the only way is to do it with an original remote. BUT your in LUCK. http://remotes.com or 1-800- remotes has the remote you need for $27.38 + shipping. Good Luck
May 27, 2006 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
RCA F32450 32" TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
