The F3-E2 error code says that the oven is getting too hot and the oven sensor would need to be replaced because the control board has detected that the sensor is not telling the control the correct tempature.HOWEVER a defective sensor will in way way make the broil element stay on and thusly i believe what is wrong is that a relay on the control board is stuck and the control board should be replaced.
I belive the reason your getting the F3-E2 code is because of the broil staying on and indeed the sensor is telling the control its too hot since the heat wont cut off.
GENE
Hi
F3-E2 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
