Giving me a Sevice Error 00010005 - Office Equipment & Supplies
Posted by Ashlea Giddings on
kenneth njonjo
    Top Expert:
  • 1,575 Answers
  • This error means there is a problem with your printers carriage operations
  • Check the carriage and the cartridges.
  • Remove anything that could be in the way of the carriages.
  • Check the cutter cap which if may also be a cause.
Thank you!
Posted on Sep 28, 2011
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
May 02, 2018 | Epson Office Equipment & Supplies
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
NO SIM error on S3 i9300. Replaced tray , fault still exists
just call your sevice provider with a pubile phone and call because your sim is spoil so change at your sevice provider sevice centre
Sep 05, 2013 | Samsung Galaxy S3
Error message: Service Call Error 00010005
This code is usually appearing when the carriage for the print cartrige is restricted by any foreing object or by displacement one of the print cartrige that is rubbing on top of the cover,
Open the cover and make sure the carriage is free of anything try to move it manually to see what can cause this blocage Hope this answer your question Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Office Equipment & Supplies
What this messege means: Error711: the operation could not finish becouse it could not start the remote access connection manager sevice in time. please try the operation again
An application you're using is trying to start a software component (the so-called "remote access connection manager" of your operating system (I'm assuming Windows here). It's taking too long to start the component however, so the application assumes there's a software glitch aborted whatever it tried to do. Try reinstalling the software that's giving you this error message.
Mar 12, 2011 | Computers & Internet
It is giving h2 error
Press # Introupt C introupt 14 Start Or Press # Introupt C introupt Start 15 or Press # Introupt C introupt Start 16 or Press # Introupt C introupt 17 Start ,
One Of The Above Will Solve The Problem iF Not Call Service
When You Press # Introupt C introupt Display goes off then press 14 or 15 or 16, or 17 then
Start . Mine Was Back In Sevice By
Nov 13, 2010 | Sharp AR-5320 Black and White Copier
In the midle of the screen it shows contact sevice
You have to resoftware the phone by giving phone to any authourized service center
Sep 27, 2010 | Cell Phones
Service Call Error - 00010005
This error 00010005 popped up when I was messing with my Print head for cleaing purposes.when I put the print head back into place the lever mechanism that is attached to the cutter blade detached from itself not allowing the printer to move the print head freely.below is a picture I scanned in from my Quick Reference Guide that shows how the mechanism should be. When I saw this I then realised what had happend and was able to put down the cutter blade to re attach the lever mechanism. After this I did not recieve the service code again and the print head was able to move freely. I hope this helps.
Oct 20, 2009 | Epson Stylus Pro 9800 InkJet Printer
Whene i start my 9880 it giveme a 00010005 error call service waht can i do to solve this problem? thank you.
Make sure there is nothing blocking the carraige (where the cartridges sit).
If there is nothing blocking it then the printer will have to go to an Epson service centre to be repaired as a part needs replacing.
Sep 03, 2009 | Epson Stylus Pro 9800 InkJet Printer
745 people viewed this question
Ekse
Marvin
Marvin
