Hello Phillip! We are terribly sorry to hear of your concern with your Whirlpool Refrigerator. We would recommend the use a Local Certified Technician in your area to properly replace that water line. Please respond back to this email address [email protected] with your name,user id (Phillip), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We look forward to your reply.
SOURCE: How to remove freezer door
push colored rings toward white collar while pulling hose from coupling
SOURCE: Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
SOURCE: load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
SOURCE: i have water standing inside the crispers, shelves
I beleive that your thermostat is faulty which is causing an excessive build up of ice.
SOURCE: Whirpool Gold Refrigerator Ice Maker not making ice
check your cutoff sensor, it is most likely a rod that will push up when the ice bin gets full, make sure its not stuck in the up position.
