Keyboard stuck - Computers & Internet
Posted by Jose Tomatala on
  • Jose Tomatala Sep 28, 2011
    Thanks a lot. It is very pedagogic....I will go through and revert asap. With Kind regards
    Jose
Reymond C. Agulay
    Scholar:
    New Friend:
  • 39 Answers
If you are addicted to your laptop, or are an overzealous typist, you may be dismayed when a key on your laptop becomes stuck. However, just because a key gets a little sticky, you don't have to run out to the computer repair shop. There are plenty of practical steps you can take to fix your stuck key right at home that don't require any fancy equipment, just regular household items.
1.Clean the area around the affected key. Use a damp cloth to clean the surface of the key (and surrounding keys) and then use a dry cotton swab to clean under the stuck key. Be careful not to pry the stuck key up with the cotton swab, as this could break the stuck key.
2.Press firmly on the stuck key. Sometimes after small dust or particulates are removed, the stuck key will pop back into place. However, if this is not the case, continue on with Step 3.
3.Pull out the fingernail cleaner extension of your fingernail clippers. This is the flat extension with a little hook on the end. Place the small hook under the left corner of the stuck key. A common reason that keys get stuck is that the collapsible spring becomes off-center. Gently push the key from side to side until it clicks into place. If this does not happen, you will need to disassemble the key completely.
4.Lift the top part of the key with the fingernail cleaner. You will see a collapsible plastic hinge (this is known as the Key Retainer) as well as a little rubber piece. Take both of these out. You will see a flat surface. Run the cotton swab across this surface to remove any dust.
5.Place the key components back in the keyboard. Place the rubber part on top of the metal circle you just cleaned with the cotton swab. Then place the key retainer (big side down) on top of it, and "click" it into place. It is very important to be careful with this step as these small parts break easily. Then place the stuck key on top of these parts and then give it a solid tap to click it into place. Your key should work now.
Posted on Sep 28, 2011
My number 1 key on the numberpad is stuck
Step 1:
What sort Of stuck ?
A stuck key on a keyboard is one of those annoying things. The typical desktop keyboard has about 104 keys, a laptop keyboard has a few less. The problem of a stuck key can be a hardware or a software problem or the key itself might be the culprit.
Hit the key several times. This will almost always unstuck a key. Clean the keyboard with an approved keyboard cleaner. These often come as wipes. People sometimes spill food and drink that can make keys sticky. Pop the keys out using a small knife or flathead screwdriver. Most keys pop right out and can be pushed right back in place. Look for something that might be blocking the key and remove anything you find.
Feb 10, 2013 | Dell Computers & Internet
Fix 3 beeps on a laptop and can not start up
3 beeps keyboard
desktop or laptop ?
Keyboard is not connected properly. Stuck key Bad keyboard Bad PS/2 or AT port Solution Keyboard is not connected properly Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. b>
Jan 19, 2013 | Dell Dimension 2400 PC Desktop
Error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
May 04, 2010 | IBM ThinkPad 390X 2626 Notebook
I just replaced my keyboard with a new one. Now,
the sleep button on your keyboard must be stuck
even though the key might not be stuck, the connection inside the keyboard might be stuck which makes the computer go to sleep again and again and again
try using a different keyboard
Sep 29, 2009 | HP Pavillion ZV6000 Notebook
Can you help me unlock my keyboard
YOU HAVE TO REMOVE THE KEY BUTTON AND TAKE THE KB APART AND PUSH THE BUTTON BACK UP , THE SWITCH IS STUCK AND A CAN OF COMPRESSED AIR MAY JAR LOOSE THE STUCK KEY WITHOOUT TAKEN THE KEYBOARD APART. THE SPRING IN THE KEY SWITCH MAYBE STUCK ALSO
YOU MAY HAVE TO BUY A NEW KEYBOARD.
ROD
Mar 03, 2009 | Logitech Cordless Desktop EX110
Keyboard is stuck and need change boot order
You can try connecting an external keyboard. When the external is connected the BIOS may ignore in built-in keyboard, bypassing your keyboard error.
You can also try removing the stuck key by prying it up GENTLY.
The answer to your question is unless you can get a working keyboard connected to your computer there is no way to change the boot order. Without a working keyboard you can't get into the system setup (BIOS), nor can you press the correct key.
Jan 10, 2009 | HP 418446-001 - HP Special Edition L2000...
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No...
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Bad PS/2 or AT port
Good luck and kind regards
Jan 05, 2009 | AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
Dsfsdfd dsf dsdsf d fdfdfdfdfd sdff fds?
i think something is stuck in your keyboard or your keys in the keyboard are stuck namely dsfsdfd dsf dsdsf d fdfdfdfdfd sdff fds try yanking it one by one or replace it with a new keyboard because your keyboard maybee having alot of dust stuck inside causing to stuck the keys,,, thank you and have a nice day.
Dec 11, 2008 | Dell E193FP 19" LCD Monitor
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
403 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
