Does it pump all the water out and then just do small agitations backwards and forward and never engage into the rinse or spin cycle and never come up with a fault code, if this sounds like your problem then can most probably help as I have to encountered the same problem before and now know how to fix this fault.
Yes that is exactly what is happening. Help please?
Ok then to first verify what I think is wrong with it you are going to have to lean the machine back somehow so you can see underneath. Once youve done that you should see a large round plastic cap, is there signs of brown water stains on this part because it sounds to me like your machine has been leaking water through the main seal and the water has washed the grease out of your main bearings making them very tight. If you want to change the bearings yourself , I can give you step by step guide but it is not for the faint hearted as it requires basically dismantling the hole machine.
