SOURCE: Hoover washing machine not spinning
Possible your outlet filter is blocked, check this out first, then your outlet pump, and clean it; refer to your manual.
SOURCE: Drying cycle runs but does not dry clothes
more than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions 2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
SOURCE: Drum Paddle broken Hotpoint Aquarius
The paddles in the drum are there to agitate the clothes being washed. Without them, it is possible that the drum would just spin while the clothes sat still at the bottom.
For optimum performance, it is best to have all the paddles present, but if one is broken/missing then it shouldn't have too much effect.
Hope this helps,
Matt
