Hi Error
code F7 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
this helps...please post back for further assistance. Daniel
F7 code usually means a stuck key on the key pad. Some of the keys can be unstuck, but if high heat caused the pad to warp it might not be repairable.
You can try giving the oven a hard reset by disconnecting the power for 20-30 minutes, then restoring the power.
It looks like I need to replace the control board. How much does that cost if I have a GE repair man do it? Or how would I get one myself?
