Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Hi leo,thanks for advice,i'm still trying to find the fault in the fridge freezer,the condenser is hot,the temp in the freezer -15C,how do i find the faut
Posted by adrian dobrea on
Leo Ponder
    President:
  • 3,773 Answers
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 28, 2011
Fridgemaster MS91562FF American Fridge Freezer brand new but the fridge is 15C It needs to be lower? How do i do this?
then call that delivery person and demand it back . but there is a dial in the fridge part to adjust the temp just turn it to a higher number for cooler temp
Jan 10, 2016 | Fridgemaster Refrigerators
Hi, I've got a Hotpoint RLS175 fridge which doesn't cool. At first there was a buildup of ice on the rear of the fridge compartment but now it doesn't cool at all. At first I thought it was a...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
need more help go here:
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 20, 2011 | Hotpoint RLA50 Refrigerator
I have a GE Profile fridge that is pooling water inside on the bottom portion of the fridge and dripping out onto the floor in front of the fridge. I checked the freezer portion of the fridge and found...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Leo Ponder
imufo2
Aug 14, 2011 | GE Refrigerators
My hotpoint frost free, fridge compartment keeps collecting water at the bottom of the fridge. I've checked drain hole is clear of any bits. The temperature strip in fridge is constantly black and ...
Leo Ponder
imufo2
Aug 14, 2011 | Hotpoint FFA60 Bottom Freezer Refrigerator
I have a aeg santo 91842 4i, integrated fridge-freezer, just over 2 years old.-i know just out of ganantee!! it keeps leaking water from the bottom, (underneath the freezer compartment),and i just cant...
If the drain is clogged with Ice or ? it overflows into the ref.
Leo Ponder
imufo2
Aug 07, 2011 | AEG Refrigerators
Hi I got fridge from charity shop hotpoint FF71S fridge freezer, and fridge is not cool enough, I do not have manual, can you help me please! Thanks Syeda
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Leo Ponder
imufo2
Jul 27, 2011 | Dometic Refrigerators
My fridge is acting up. The freezer section is very frozen and the fridge section is warm (room temp). I tried unplugging the fridge for 2-4 hours and after plugging it back in, it seemed to work OK for...
I'm Leo
If this was helpful please rate me
Leo Ponder
imufo2
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
Jul 26, 2011 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Our Whirlpool Bottom Freezer Refrigerator (model EB9FVHXVQ)has been acting up for over a month. The freezer is VERY frozen and the refrigerator section is warm (room temp). I tried unplugging the fridge...
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Also check evaporator fan in freezer
Leo Ponder
imufo2
Leo Ponder
The freezer works fine but the fridge is not cold. Fridge set at 8, freezer at 9
I'm Leo
Leo Ponder
imufo2
Leo Ponder
Jul 23, 2011 | Maytag MZD2766GES Side by Side...
Kenmore 10654382300 side by side
Hi Vince,
Thanks for the posting in FIXYA.
Please repair the Freezer door as it is not sealing, due to which cooling is affected. If it is under warranty then contact to the manufacturer as soon as possible.
Regards
ELLIN
Sep 15, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
61 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
