Question about Sony PlayStation Portable (PSP) Console
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in. I know it is not the charger as i have already tried another one. Does anyone know what is wrong?
Anonymous
    New Friend:
  • 72 Answers
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Posted on Sep 28, 2011
1helpful
My PSP will not turn on unless it is plugged into the outlet. When I try to turn it on by itself the power light flickers green for two seconds and then disappears. Also, the battery is fully charged. When...
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I charged my PSP with a universal charger and wrong polarity. My PSP immediately shut off. when I tried to turn it on again it would not turn on, and the green light does not light up either. when I charge...
Sounds like the battery is charged fully. If you know someone else who has another psp, try putting the battery into his/hers and see if it starts up. If so, your psp may have been fried. There is not much you can do.
How do i reboot my psp?
Have you tried turning on, but then hold the power switch down for around 10-15 seconds or until the power light simply turns off, no flashing. If not, then you should jump on the internet and look for a so-called Pandora Battery and Magic Memory Stick. They will actually install custom firmware on your PSP which you can remove later on, but if you use those, it should unbrick the PSP, so you can use it again.
My PSP does not charge
your charger must be out of order...
1helpful
Fully charged cellphone battery drains in a few minutes
relpace your mobile battery and avoid overcharging and charging overnight
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
1helpful
Phone turns off every couple minutes and then turns on by itself.
What I would do is turn it off completelly for a few minutes. take out the battery and let it cool down for a few minutes. If you have a battery that if fully charged put it back in and turn on your phone. if your battery is not totally charged, charge it. A phone whose battery is not fully charged may cause your phone to flip out. sometimes it's also water damage to the phone that causes it to turn off on its own.
Water damage happends from body heat, from taking it to the bathroom when you're in the shower, or from putting it directly in water.
Hope this helps.
2answers
PSP not turning on
My PSP stopped turning on and when the charger is plugged up it gives me the green light but thats it, should i try a new battery???
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
Oloyede Monsuru
Steven Wander
Steven Wander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
