SOURCE: I have an echo pb 265l leaf blower. It starts
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
SOURCE: I have the Echo PB 265L leaf blower.
I had the exact same problem with gas soaking my back and found out the yellow fuel discharge tube that comes out of the carberator was not inserted into the rubber gasket on top the fuel tank. The gasket has 3 holes in it for 3 tubes and the yellow tube fits into one of the holes. Hope this helps. It is a bit difficult to get the tube in the hole, but at least if you know what you are looking for you can get it to work
