Question about Honora Watch
I cannot set the time on my Honora Floating Pearls watch. When I press the time setting button, nothing happens. The watch is working and so is the battery.
Posted by Jill Murray on
Cindy Featherston
    New Friend:
Use the "******" part of the buckle to press in the dimple in the center of the back of the watch..Juse did on the on I got from Rue La La & that worked.
Posted on Oct 08, 2011
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
Honora watch does not have stem - how do you set the time?
This is a newer kind of movement. All you need to do is take the stem from the watch buckle and press & hold it into the circle at the center of the back of the watch. This will cause the hands to start moving and the movement to start. Once you get to the correct time, please remove pressure and the watch will be set! I hope this helps!
Aug 14, 2010 | Honora Watch
My wife has a Nike Alpha Project watch with new battery. We cannot set the time. I press "Mode" and nothing happens. I hold it down and nothing happens. Perhaps the buttons do not work? Shawn
Maybe the button is not pushing the internal button properly. Undo the back and remove the watch unit from it's case and then see if it works when you press the internal button.
Aug 02, 2010 | Watches
The glass cracked in my Honora, how can I get a new glass?
if you are in the USA:
if you are in Europe:
Search Results AQUALAND WATCHES § ROLEX DEALERS IN LONDON HONORA WATCHES ... Day shipping to uk france greece brazil germany australia. ... 1350s aqualand watches no laser cooling of astronomers. Indicating eclipses or inform ...www.pokerwebtown.com/uuiwqd/aqualand-watches.html -
Jul 31, 2010 | Honora Chronograph Watch Black
How to set the time on a breo watch?
Received my Breo watch in the post today, and i thought it would be simple enough to change the settings...however when i press the A and M button on the back nothing happens, i've pressing it lightly and with more pressure but to no avail. the manual just says to press it, so am i doing something wrong?
Jul 02, 2010 | Watches
I´ve had the same problem with two Breos. That´s what I did: I opened the watches put out the battery, put in the same battery and that´s it.
Apr 16, 2009 | Watches
How to set a Honora chronograph watch
You have to upload here all details of the watch: model, ref. number. Movement number and good pic would be very helpfull.
Dec 20, 2008 | Chase-Durer Typhon Chronograph White Dial...
Casio baby G watch model 3786 (can't change digital time)
Im a watch technician,and when im make adjustment to a new watch for me i dont need any manual,the thing ive done is keep pushing and pressing the button and observed what happen and the result i write what im discover new to me.When setting a baby g watch find the set and press it for 10 seconds.then your watch will flashing then go to mode button and choose what you are going to set.The hour ,the date ,the alarm whatever is there to set desame you going to do , only the set button need along press.Message me whatever you discover .
Jun 18, 2008 | Casio Baby-G BG370S-4V Wrist Watch
Watches Logo
298 people viewed this question
Top Honora Watches Experts
Bruce Robin
Lisa Christine
Lisa Christine
Marvin
Marvin
Are you a Honora Watch Expert? Answer questions, earn points and help others
