The detent that is mounted to the inside of the base cover is not working either because the screw holding has broken off or it is worn out. You could also have a worn out fan housing since that is what the detent catches to make it stand up. If the screw is broken off the only way to repair it is to replace the housing. Hope this helps.
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
(1) Upright: Sounds like the tab on the lower handle that the handel release latches to has broken off. The machine is fully functional without it otherwise.
(2) Assure the ring gasket is in place under the hood.A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552957 Generic problem for all Vacuums Hose connection broken. Posted by nualaheaneyi on Apr 28, 2008
Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If you have a broken hose connection, and not knowing the brand name of the vacuum, I can suggest 2 things. If you have an electric hose, meaning that it is attached to a electric power head or power nozzle, some can be repaired depending on what was wrong, but most of the time you have to replace the hose, some pigtails can be replaced but if the electric connection is broken, you need to replace the hose. If it is a non-electric hose, you can use a shrink tube, or cut out the broken part and use a hose cuff to join them together, so just shorten the hose and screw back on the original ends. In either case you need to check with a local vac dealer. Or you can make a new hose with new ends and leave the canister @ the bottom of the stairs and go up with just the long hose, unless you have an upright then you have to make it the length that is on the upright. Or replace it with the genuine hose from the factory or use the ends from the old hose on the replacement hose. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Thanks,Don – The Vac Man Go Ahead.Use Us.
