Question about Sumvision Sempra PRO Digital Media Player
Can the sumvision cyclone micro media player adaptor firmware be updated.
5 Related Answers
Anonymous
SOURCE: sumvision cyclone multimedia player firmware lost
Drive should be formatted in FAT32. This is more preferrable than NTFS
Firmware for Cyclone is
_mpd1100_ (do not rename)
check google for cyclone firware upgrade to get latest firware file as named above
Drive needs to be blank.
Transfer extracted file to the disk
Use Setup -> Firmware Upgrade. Confirm after F/W compare.
hope this helps
Posted on Jan 13, 2009
Anonymous
SOURCE: Sumvision Media Player not working with tv but ine with computer
Have you formatted it to Fat32?
Posted on Jan 26, 2009
Anonymous
  • 10 Answers
SOURCE: Problem accesing my Sumvision cyclone media player through my tv
Posted on Aug 12, 2009
Anonymous
  • 10 Answers
SOURCE: firmware for cyclone mmp
http://www.sumvision.com.cn/drivers.aspx Its the second one down where it says firmware when its downloaded extract it onto the hard drive make sure there isnt much files on the hard drive then connect to tv go to setup select firmware and press play to update.
Posted on Aug 15, 2009
Anonymous
  • 6 Answers
cx3200:
SUMVISION CYCLONE 1 Tb REC/PLAY HDef Media System :
If After Formatting Hard Drive for 1st Time Your Screen Goes Blank and after Cyclone Logo Screen has Loaded:
Press TV System Button on Remote Control a few Times , and you should be able to view the Menu Setup Screen and Adjust for Pal / ECT::
The Cyclone Sometimes Jumps to the High Definition Output Setting and you Need to Do this to Adjust the Output for your TV ect:
I Had This Problem and I Phoned Envizage for the Solution which Worked , and i Have Restored my Menu :
Posted on Jan 28, 2010
How to find internal storage on cyclone micro 3
There is a "Firmware" update to Cyclone micro 3 .This can be downloaded from Sumvision web site :-
http://www.sum-vision.co.uk/productinfo/micro3b/micro3b.asp
When downloaded copy the file on to a Memory stick or card and click the USB entry or memory card entry on the main menu, and the Cyclone will update itself .
There should now be an entry on the main menu for "internal storage"
SUMVISION CYCLONE MICRO DOES NOT SHOW ALL MOVIE FILES ON EXTERNAL HARD DRIVE
Some video formats may be incompatible with the player.
Your laptop probably has more codecs, so more compatibility.
Try a program like Video Inspector to see formats of different files.
4helpful
Cyclone media player firmware problem
Sumvision Cyclone Latest Firmware Update
Latest release of firmware to fix customer who may be experiencing "menu" problems or large HDD problems:
Please download the .zip file from the link below:
http://www.digitalpromo.co.uk/images/cyclone%20upgrade.zip
Then follow these easy installation instructions:
Info: Hard drive must be either new or contain very little data for this update to work.
1.) Extract the file
2.) Put it in the root of the HDD
Note: Dont change the file name, dont put it in a folder
3 .) Power the device on, go to the "setup" section, and click the upgrade firmware
Regards
1helpful
3answers
CYCLONE MEDIA PLAYER firmware up-date that allows .MKV
The player does not support .MKV files if you update the player it will still not play .MKV files the update is just to fix problems with the player.
Firmware update issue
The firmware file isnt a VLC file it is a .bin file you can get the file off sumvisions website http://www.sumvision.com.cn/drivers.aspx it is the second one down.
Firmware for cyclone mmp
3helpful
Can't see Sumvision Cyclone HDD on PC
see this link
http://docs.google.com/Doc?id=dgcfqncj_0cnqvx5gt
Sumvision Sempra PRO  Digital Media Player Logo
Top Sumvision Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
