A - From the Windows Mobile user interface:
1. Tap Start (the Windows Logo), then Settings.
2. Tap the System tab.
3. Tap the Power icon.
4. Tap the Advanced tab.
You can change the number of minutes before power is turned off when on battery and when on external power from there. You can also uncheck the "Turn off device if not used for" check box to disable the timeout entirely.
B - From the registry (useful for deploying the setting as a .reg file to the device, in case you have many MC9090 guns you are supporting or you are wanting to set it to a value the user interface does not support):
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"BattSuspendTimeout"=dword:00000000
"ACSuspendTimeout"=dword:00000000
The above values are in hex and represent the number of seconds before timing out when on battery or AC power. For example, to set the BattSuspendTimeout to 180 seconds, you would set it to dword:000000B4. To disable it entirely (the equivalent of unchecking the checkbox in the user interface), set the value to 0.
Thanks,
Brad Radaker
Radicomm, Inc.
(makers of QuickTalk - push-to-talk over WLAN for MC9090)
www.radicomm.com
