SOURCE: NOKIA 6600 turns off by itself
try it with the 3key format trick. if your phone shuts off for 30 seconds the UEM is the faulty part.
SOURCE: phone is dead?
Try leaving the battery out overnight and then put it in again the following day to see if it turns on. If not, then a reflashing of the phone is needed. Try to flash it with NSU (Nokia Software Updater) from Nokia's site. If this doesn't work you will need to send it off to be serviced. Good luck!
SOURCE: My Nokia 1200 Won't Ring!
all your contacts belongs to Private Group... Remove them from this group.. or delete theme all and save again...
Plz rate me...
Thanks...
SOURCE: Nokia 6111 turns itself off after a few minutes when turned on.
You have to eject external memory card and after some time insert in your mobile and start. If this got again problem do it for 2-3 times . After that it will work.
SOURCE: nokia 6300 keeps turning itself off after a few
hey
just format your phone and remove everthing on it
