Question about Panasonic KX-T7730 Corded Phone
We have a KX-T7730 telephone with 3 incomming lines. We are unable to hear it ring when on another call. Is there anyway we can change the settings and how? we have tried pressing Program, code 3, ring lines 1,2,3 and still this is not working? Help us
Posted by Justine Riddle on
Shawn Glass
    Problem Solver:
  • 16 Answers
Try pressing Intercom then 7311 and 7321. You may have to hit the pound key after each one.
Posted on Oct 02, 2011
Cant hear incoming calls on my corded audiosonic landline telephone
Is your sp-phone working? if not, then you need to replace
the speaker unit. if it is working, then check if :
1- ringer switch set to off.
2-System programming is set to no ring for your extension.
Nov 04, 2013 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How to configure panasonic exchange Model KX-TEM 824 to work with telemanager call tracking software using telephone KX-T7730
    It's pretty straightforward. The DB-9 connector on the cabinet is turned on by default for incoming and outgoing calls, so all you have to do is connect your serial port to the Panasonic serial port at 9600,n,8,1 (default). In the Maintenance console, tab 1.7 adjusts the output. How you set up the software is part of the manufacturer's instructions. The Telemanager software on my search engine was designed for the NANP only.
    Carl
    Mar 01, 2011 | Panasonic KX-T7730 Corded Phone
    How to set a new CO num into kx-t7730? screen is appear "CO not assigned"but the line already plug in .
    In analog system like the KX-TA series, the lines have to be both installed and programmed to a set. System program 400 sets the lines and pressing PROGRAM, a CO button on the left side of the phone and dialing 0x STORE sets the line on the telephone.
    There are also some access and ringing programs that need to be done in system programming and they are located in sections 407-412 or so.
    For example, if you added line 3, you would go to 400, make sure that CO 3 is enabled, then press PROGRAM on each phone and the 3rd button up from the bottom. If the display doesn't say "CO3", then you dial 03 STORE and that will set line 3 on the phone.
    Carl
    Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
    On 308 pansonic pbx (kx-t7730), when the incoming call rings all the extension phone and the master (PT or operating console)phone rings.so please help me to make it ring only on the master.thanks
    When you take this unit out of the box, you get programming instructions. One of them is the ringing (program 408) for day mode. (409/410 for night and lunch). By default, all phones ring on all lines in all 3 modes. You have to remove the ring to make it go away.
    Carl
    Sep 29, 2010 | Panasonic KX-T7730 Corded Phone
    KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
    3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
    4. Press AUTO DIAL / STORE to save your changes.
    5. Press PROGRAM to exit program mode and you are done.
    Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
    1 lines is ringing & another is not ringing
    Somewhere you should have a programming and operating manual for your phone system. Typically in a Panasonic you turn on CALL WAITING for both Intercom and Outside lines via a code you dial at each phone on the intercom (7311# 7321# for a TA).
    This is assuming that the lines are already programmed to ring at the phone.
    Carl
    Aug 21, 2009 | Panasonic KX-T7730 Corded Phone
    How to change ring tone of kx-t7730
    sir please i want to when call my consol i'm not there i picup phon our telephone set plz suggest
    Jun 16, 2008 | Panasonic KX-T7730 Corded Phone
    KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
    please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
    Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
    Tone delay
    Here is a link to the operating manual which may help :
    http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
    You could try disconnecting the phone by unplugging it for abaout 10 seconds, then all phone settings would revert to manufacturers default settings.
    Jan 21, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    303 people viewed this question
    Top Panasonic Lands Phones Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Henk de Ruiter
    Henk de Ruiter
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
