Question about Beverage-Air MT27 Beverage Cooler Commercial
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Posted by www_cottonba on
David
    New Friend:
  • 4 Answers
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Posted on Nov 18, 2011
Wally Bald Guy
    Guru:
  • 683 Answers
It is at the compressor
Posted on Sep 27, 2011
Why is my Beverage-Air refridgerator running all of the time?
Door seals torn, poor air circulation over condenser coils or evaporator coil, defective thermostat, not defrosting or low on Freon.
APPLIANCE 911
Dec 15, 2015 | Beverage-Air MT27 Beverage Cooler...
Can i use a beverage air mt27 as a freezer
doubtful but if you turn the dial to highest cold number what is the temp only you ca tell that
Mar 22, 2015 | Beverage-Air MT27 Beverage Cooler...
What will make a beverage air mt27 not cool
Multiple reasons. Is it turned on & set. Is the fan inside & out turning fast. Is there frost on a line at the compressor Is the compressor outside cabinet s/b hot & vibrating continually. Is the condenser (attached to compressor with radiator) warm/hot & not plugged with lint etc between the fins. ?????
Jul 01, 2014 | Beverage-Air MT27 Beverage Cooler...
How to add refrigerant to mt27
You should check the condenser to see that it is clean. Is the compressor running? If you have a leak, putting in gas wont help. You need to look for oil on the components around the compressor, inside the cooling coil housing. Hope this helps good luck.
May 01, 2014 | Beverage-Air MT27 Beverage Cooler...
Wiring
Yes they do with majority of models...
May 11, 2013 | Beverage-Air MT27 Beverage Cooler...
Beverage Air
1. check for dirty condenser sometimes if its dirty enough, it'll trip the compressor.
2. if condenser is dirty, well pull out the old garden hose and hose down the condenser (turn off unit first!)(i don't want any accidents... je je je)
if you did step 2 and nothing yet, suspect faulty relay/ overload/ start capacitor failure (relay and start capacitors fail more often then the overload.
hope to he of some help today.
Jan 30, 2008 | Beverage-Air MT27 Beverage Cooler...
Beverage-Air MT27 Beverage Cooler Commercial Logo
552 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
