Question about Brother MFC-7820N Printer
Paper jam displayed but no paper jam found. Cleaned with air but this did not help. Seems like printer wants to keep resetting itself.
Posted by David Fugh on
Dotty Hopkins
    New Friend:
I had this problem and someone on Fixya solved it. Open the back cover and slide the guide slightly. If it's off center it won't work and gives you the jam message even though there's no jam. It solved it instantly.
Posted on Nov 02, 2011
Keeps saying paper jam,but no paper jam is inside
The jam indication is set because the sensor(s) detect one. This could be due to a buildup of paper dust, a small bit of a sheet that tore off and got lodged deep inside when removing a previous jam, or damage to the sensors if the jam was removed forcibly by pulling the sheets out from the wrong direction.
Dec 10, 2015 | Brother DCP-7020 All-In-One Laser Printer
My Officejet 6500 keeps saying "paper jam" even though I am sure there isn't any jam. A search of the internet let me to disconnect power cord for 30 seconds and press # 3 to reset the machine. ...
Hi I also had this issue. no paper anywhere but still the message. I found out that it was also not possible to move the carriage. I teared the device apart. found out that the ink cleaning mechanism was so filled with old and sticky ink. I cleaned it all,what a job..wear gloves I can now advise..and then it start working again...
Nov 12, 2010 | HP Officejet 6500 Wireless All-in-One...
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
HP C4385 display reads Paper Jam continuously
check the paper jamed or not other wise try to reset your printer
Oct 03, 2009 | HP LaserJet P2015dn Printer
Paper jam
I had that problem quite a few times. i had to reset power to my computer and the printer on each occasion. seems to reset itself from there.
Jun 11, 2009 | Lexmark X73 All-In-One InkJet Printer
Paper jam removed and now it only resets itself and won't print
Please switch power off first before touching !!!
Check the doors are closed properly, you can get errors if not.
check the back too for particles of paper, open it then close again, double checking doors.
plug it in, try again
Hope this helps
Regards
Apr 16, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Brother MFC-7820N Printer Logo
181 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
