It could be a ceramic fuse that is usually located inside the microwave, you need to remove the cabinet. You will see it place there on top (usually) or it could be under a cover there. Be sure to replace this with a like fuse, nothing too small or too large. You should also be sure to use a ceramic fuse, as a glass fuse will burn out much quicker and you'll be in the same spot.
Hope this helps,
Joe
