I would certainly find a bad capacitor in the standby(deflection area). You are not getting the correct voltage to keep this set in standby. A bad capacitor will over correct the voltage,and create a high voltage shut down. I have not repaired this particular model. I would look for a 160 to 250 volt capacitor (sometimes two) at 1 Mf, 2.2, 3.3 or 4.7Mf. These will always go down. Please inspect check and replace these. Your TV may come back on. If it will not power up, chances you have a bad picture tube.A bad picture tube will also do as you describe (Rare,but can happen). Thanks for asking and show all hands of support!
Hello
This is a short circuit indication. There will be some kind of circuit short on the main board of this tV. Just check it. The most common fault I detected so far is with horizontal output section. Check that section for any faulty or leaky components. The work is a very skilled one, and you must have through knoledge in electronics, and all testing equipements and you must have the awareness to use these testin equipments. Eventhough the fault is a simple one, detecting the actual fault point is a very skilled job indeed. Check these I've stated above. If you want anymore assistance from me, feel free to get me by FixYa. OK.
Many of these later model Toshibas were assembled by Orion electronics. Orion. Ilo and Durabrand and Sansui TVs have the same boards. There are many bad caps. Replace 35 @50 volt !Mfs caps.There are several of these. Replace the 35 volt 100 Mf in the vertical section. Thought you would like to know!
Should read, 35 to 50 volt 1Mf caps.
