SOURCE: GE Advantium stopped working completely...indicates no power but it is on.
It may be that your high voltage diode or capacitor has shorted.
The fuse is usually located behind the grille, on the
floor of the oven behind the control panel, between the door switches,
or on the filter board near where the cord comes into the unit.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
Here are some links you
or someone you know can use (in order given) for test help, but read
the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted,
it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even
though it is bad!)
http://www.gallawa.com/microtech/xformer.html
To check the high voltage parts, you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
